Initial Research Questions
A project log for Variable Pitch Small-Scale Wind Turbine
Developing a 3D Printed Variable Pitch Wind Turbine
williamrigbywilliam.rigby 03/30/2022 at 12:210 Comments
The following research questions need to be addressed before detailed design can be commenced.
  1. Ideal airfoil profile for wind turbine.
  2. Median Wind Speed in my location (Southern Tasmania) for peak efficiency.
  3. Turbine RPM at this speed
  4. Appropriate Brush less motor that can be direct driven or driven using off the shelf gear box.
