PolaPi v2.0
inspired by PolaPi (https://hackaday.io/project/7176-polapi) i did an improved version
Polaroid like camera that prints on thermal paper, using common hardware and a raspberry. inspired by <a href="https://hackaday.io/project/7176-polapi" target="_blank">https://hackaday.io/project/7176-polapi</a> but as he hasnt added any updates and some things have changed i thought of writing down my experience and ideas
This is my first project published, so if i miss something and you cant follow, just write me and i try to improve the tutorial :)
First of all this is not my project, i just did use this project PolaPi (https://hackaday.io/project/7176-polapi) and modify it so it fits my needs.
And i want to write a complete documentation with all steps as the project is not an easy to follow tutorial.
Case3.0.eps
New Case without screws
postscript - 2.77 MB - 05/21/2017 at 14:10
Download
Circuit Diagram (raspberry, step down, Lipo, Printer, Camera, display
Portable Network Graphics (PNG) - 849.24 kB - 11/22/2016 at 11:57
Preview
GPIO Layout on 3D Systems 3,5" Display
JPEG Image - 380.33 kB - 11/22/2016 at 07:48
Preview
gunplay rg.ttf
Gunplay Font used in Adobe Illustrator Lasercut File
TrueType Font - 55.87 kB - 11/22/2016 at 07:39
Download
caseplans3acryl-12schrauben-rundeloecher_cleaner_kleinereabstände.ai
Adobe Illustrator LaserCut File (150x100x100 M3 12mm)
postscript - 59.07 kB - 11/22/2016 at 12:02
Download
  • 1 × Raspberry Pi 2 Works with RPi 1B+ and probably with RPi Zero1.3 but not yet with RPi 3
  • 1 × Raspberry Camera module (v1.3 has a better result, but v2.1 works fine too) https://www.amazon.com/Arducam-Megapixels-Sensor-OV5647-Raspberry/dp/B012V1HEP4/ref=sr_1_4?ie=UTF8&qid=1479801489&sr=8-4&keywords=raspberry+pi+cam
  • 1 × Lipo 7,4V at least 2000 mAh https://www.stefansliposhop.de/Akkus/SLS-QUANTUM/SLS-QUANTUM-30C/SLS-Quantum-2200mAh-2S1P-7-4V-30C-60C::1658.html
  • 1 × 4D Systems 4DPi-35 (or any other GPIO Display) http://www.4dsystems.com.au/product/4DPi_35/
  • 1 × 57mm Thermal printer TTL (or from Adafruit costs more) https://www.aliexpress.com/item/58mm-micro-thermal-panel-printer-thermal-mini-printer-usb-mini-printer-mini-embedded-thermal-printer/32334172985.html?spm=2114.01010208.3.145.tWN21H&ws_ab_test=searchweb0_0,searchweb201602_5_10065_10068_10084_10083_10080_10082_10081_10060_10061_10062_10056_10055_10054_10059_10099_10078_10079_10073_10100_10096_10070_10052_423_10050_10051_424,searchweb201603_9&btsid=544b85b3-36f3-4339-81c1-49b364e8fbf3
View all 13 components
View all 4 project logs
  • 1
    Step 1
    Thermal Printer configuration/tweak
    if you bought the printer over Aliexpress, the seller will ask you which settings you want, then u dont need to do this step. If not read carefully!
    Standard baud rate the printer comes with is 19200 (you could leave it like this and edit the config file to use 19200 as baud rate) but you get better results if you change it to 115200. You need a USB to 5v TTL serial converter for this stepchange the printer baud rate to 115200 and code page US
  • 2
    Step 2
    then you have to add a stepper pin which regulates the flow control. Please be very carefully doing the next steps scratch the layer as shown in the pictures.
  • 3
    Step 3
    TTL cable modification
    cut off the green wire of the TTL Printer or just remove it, use a thin screw driver to unplug it (if you run the printer with 7,4V and attach the Tx to the GPIO of the Raspberry you can damage it, so as it is not needed we unplug/cut it, so there is no risk of destroying your raspberry)
View all 9 instructions
