Meshtastic 2.0 preinstalled!
11/05/2022 at 17:05 • 0 commentsBoth Station G1 and Nano G1 ship with Meshtastic 2.0 (https://meshtastic.org/2.0/) preinstalled from now.
Meshtastic Mesh Device Station Edition G1 has been released
08/02/2022 at 17:35 • 0 commentsThe Station Edition series is a compact Lora device with high power PA (Maximum TX Power: 35dBm@915MHz or 868MHz for Station G1 Edition), Rugged SMA Antenna Socket, rich external IO interface, wide input voltage range (8VDC-20VDC). This series aims to provide the best RF performance in all series with credit card size and rugged construction. Fixed-location base stations and vehicle-mounted base stations are typical application scenarios for this series.
For the firmware, Meshtastic firmware 1.2.65 is preinstalled. Meshtastic Mesh Device Station Edition G1 is expected to be merged into the official meshtastic repository on Github starting from firmware 1.3.
More Information:https://hackaday.io/project/186654-meshtastic-mesh-device-station-edition-g1
The Latest Firmware Support
05/17/2022 at 05:17 • 0 commentsMeshtastic Mesh Device Nano Edition G1 had been supported by the official meshtastic repository on Github from firmware version 1.2.61. Thus, the latest firmware could be downloaded from the meshtastic project’s releases page: https://github.com/meshtastic/Meshtastic-device/releases
Firmware file: firmware-nano-g1-1.x.x.bin
The Fimware may also be updated by using Meshtastic GUI Installer. Meshtastic GUI Installer is a cross platform, easy to use GUI for installing Meshtastic firmware.
More Info:https://meshtastic.org/docs/hardware/supported/nano-g1
