ATX power shield code
A project log for TARDIS Themed Board Game Cabinet
Board game cabinet with a Doctor Who TARDIS theme with door sensors, LED strips, roof light and sound
cafelizardocafelizardo 04/04/2022 at 09:310 Comments
I use the SparkFun ATX Power Shield to control the 6 PWM LED channels.
SparkFun Power Driver Shield Kit
Code snippet for controlling the ATX shield
 ATX shield with ATX control
 claude felizardo 2018-08-06
 https://www.sparkfun.com/products/10618
 Uses modified ATX shield to use pin 2 to control PS_ON control pin on ATX connector.
#ifndef _atx_shield_h_
#define _atx_shield_h_
#define ATX_SHIELD_VERSION "$Id$"
class ATX_Shield
    int atx_ctl_pin = 0;    // output for controlling ATX power supply
    int atx_enabled = 0;    // current state
    public:
    ATX_Shield(int output_pin)
        atx_ctl_pin = output_pin;
    void output_power()
        Serial.print("atx_enabled = "); Serial.println(atx_enabled, DEC);
        digitalWrite(atx_ctl_pin, atx_enabled == 0 ? HIGH : LOW);
    } // output_power
    // this should be called once
    void setup()
        pinMode(atx_ctl_pin, OUTPUT);
        atx_enabled = 0;
        output_power();
    int isEnabled()
        return atx_enabled;
    void powerOn()
        if (!atx_enabled) {
            atx_enabled = 1;
            output_power();
    void powerOff()
        if (atx_enabled) {
            atx_enabled = 0;
            output_power();
}; // class ATX_Shield
#endif // _atx_shield_h_
