Water Proof Case from Nature Bytes loaded with PIR sensor, Raspberry Pi 4 and Raspberry Pi Camera v2. Using Node Red to connect the camera with Mobile Net for image classification.
I've taking random images from the Internet to test the Node Red flow.
I was interested in both mobilenet and cocossd. Once I go live than will be using the Raspberry Pi Pin node to recognize movement from the PRI to take a picture.
Below are results from taking images fro the internet.
