Another Open PCR Thermocycler
It's a Thermocycler to do PCR, hopefully, for less than $200
Got the heating elements wired up to the transistor, and at one sample / second I'm holding at about 1 degree of flux from 100c. I'm assuming a higher sample rate will prove to get the flux down below .5 degrees.
Present total cost is at about $87
  • 1 × USB Boarduino $25
  • 1 × Half Size Breadboard $5
  • 1 × N-Channel MOSFET 30v 60A $1.75
  • 1 × TMP006 breakout $14.95
  • 2 × Electric Heating pad 10cm x 5 cm $7.80
View all 11 components
c.lamport wrote 04/30/2015 at 14:04 point
I'm interested in making one of these, are there any more details on this?
