I can happily confirm that even on the NMOS 6502 Ø2B can be replaced with Ø0 if Ø1B is replaced with ~Ø0.
This improves margins a bit and solves an issue on the NMOS 6502 that caused a few spurious writes - I guess my NMOS Ø2-pullup was not quite enough under all conditions.
Either way - this is why R1 has three of the jumper positions next to the barrel plug.
For the next revision this means I will probably throw away the buffering and just use Ø0 and it's inverted companion. I still need the 74'14 for the reset circuit - but having four left over inverters is great!
Anders Nielsen
