• Journey to the Center of the mini
    Navarre07/04/2022 at 15:14 0 comments
    Finally got a chance to pull the Mac mini apart to start investigating the connectors on the logic board.
    First up, the fan connector. This looks to be a 6 pin molex connector. I haven't had a chance to figure out which line is which, but am hoping to scope it out soon. Speculation from some friends includes +/- 12V, speed sense, and maybe some temperature sensing for the different lines.
    The power button is connected over a 6 pin FFC cable to an 8 pin board connector that apparently only actually uses 2 pins (source: "iMac G5 upgraded to iMac M1"). The thickness of the FFC cables is 0.21 mm. It looks like the LED and IR sensor FFC is the same 6 pin cable although I'm not certain if it's the same length. The board connector is also 8 pins, although it looks like the on-board connector is attached a little differently than on the power connector. I'll have to look the next time I get it apart.
    The 20 pin PSU connector was identified by some people over at iFixit working on 12V conversions, and it is almost the right connector. The keying slots (?) aren't quite the same. The Molex connector keys are short and square while the OEM is long and skinny. The pins do line up, so I think if I trim the connector it will fit in alright, but I'd love to find a better match if anyone knows of one.
  • Hmm…
    Navarre06/05/2022 at 03:12 0 comments
    So, I looked through the schematics and the 26 pin “kitchen sink” or “blind mate” connector should be a 16 pin connector. Apparently something changed between when the drawings were made and when the computer went into production.
    I found the 26 pin version of the molex connector specified, but it doesn’t look like the connector on the board. I’m wondering if this was something special that Foxconn made for Apple, or if I just need to look a little longer.
  • Pretend this was the first log*
    Navarre06/02/2022 at 15:57 0 comments
    I’m only just starting with this. I’ll try with the 17” I’ve got, and if it works well, I’ll try to get the 15” and 20” going as well. The first task was tracking down the 21 position board connector, which I’ve found on DigiKey: JAE Electronics / FI-W21P-HFE. The board connector is actually shielded, but I haven’t been able to find that variant. The spec sheet is for all of them at once, so part numbers have been tricky to figure out (at least for a newb like me).
    Second step is to trace the wires from the LCD to the board connector and cross reference with the pinouts on the display from Dremel Junkie’s website. I haven’t found a pinout for the board connector, and I want to make sure the cable doesn’t switch any of the pins on its way through the neck.
    *This is my first project on here, and this was supposed to be the first log entry, but I put it in the project description instead. Whoops.
  • Goodies
    Navarre06/02/2022 at 13:32 0 comments
    Got a box of goodies from DigiKey the other day, but I think I ordered the wrong 26 pin connector for the inverter/speaker/fan. The big one in the picture is the one on the board, and the tiny one to the right is the part I ordered. Some of the spec sheets don’t have the connector dimensions which makes things extra fun.
    I was able to track down a copy of the board schematics, so I’m hoping there’s a BOM there with part numbers, but I haven’t had a chance to dig into it yet.
  • TMDS line tracing
    Navarre05/19/2022 at 02:40 0 comments
    Today I finally got to tracing the lines from the TMDS connector on the LCD to the board connector. I need to double check everything before I commit to the board layout, but my preliminary findings are below.
    As a reminder, this is an 800 MHz, 17" G4 iMac. The descriptions and cable colors are from DremelJunkie's website (http://www.dremeljunkie.com/2011/08/guide-step-by-step-17-imac-g4-tmds-to.html?m=1).
