The goal of this project is to replace my current smart watch (Apple Watch Series 2) which is very much outdated at this point. It may not have the features, body, or funding in the same way, but at least I'm able to repair it myself. At some point, this project will become open source and have building instructions for people to make it themselves, but for now, it will be closed source.
Updates to this project will hopefully come on a somewhat weekly basis, but no guarantees.
Ok ok ok... but here me out, right? I just got a couple of great ideas that I'm going to make hopefully within the week if I don't get sidetracked again, alright? So just bare with me on this one...
Ideas I had:
Scrap everything except the main bits (Feather board, display, battery, piezo, switch)
The main reason for this is due to things being 1) out of stock, but really because 2) I had too many things I wanted to do and if I ordered the parts, tried to prototype, etc. etc... I would forever be prototyping and things would never get done
Use an ATtiny85 as an RTC (RTC85) and use the internal file system in the Feather as the SD card replacement and have a dumpInfo() function or something when it's wired to a computer
This does a few things for me:
Cuts down on costs and time (since I already have ATtiny85's on hand)
A cheap workaround for an RTC
Allows me to do a lot of other stuff like have a modular component to the project
Use the unregulated voltage from battery into the RTC85 (it'll probably fine, right?) to always have power
That last one definitely needs a little bit of work and the other ones require a lot of testing before actually deciding to put it in the final project. We'll see in the next devlog.
As the title may suggest, I'm not entirely sure how much progress I actually made for this project, but it's progress nonetheless. I'll let you be the judge of that, so let's jump right into the report.
Over the past couple of days, I have:
Set up 'thread based operating system'
Set up Bluetooth
Run in threads
Get current time from phone
System runs independently from connection status
Set up battery status
Run in threads
Get current voltage level and print (as voltage or percent) every 10 seconds
Get charging status and turn on/off LED_BUILTIN accordingly
Tested threading with a slow display
Once display finishes updating, system will 'catch up', before then, everything is 'paused'
Created an app cycler with a button and signal edge detector (had to look up what it was called)
Created 3 separate 'apps'
Home Screen
Prints current time through serial console
Weather App
Prints temperature, pressure, altitude, humidity, and magnetometer data to serial console
Music App
A simple script that plays a preloaded song (Song of Storms)
Song can be looped by setting a jumper to a positive voltage or finish the song by setting a jumper to ground
Song can be stopped (mid song) by setting a different jumper to a positive voltage
Some things I attempted to get working, but was unsuccessful were:
Creating a working compass (a long standing problem of mine)
Accelerometer and gyroscope data (I'll get it working tomorrow maybe)
Calibrating magnetometer and gyroscope (not entirely sure what I'm doing lmao)
Lastly, things I'll be doing tomorrow (if I don't get sidetracked):
Notifications? (with ANCS)
Clean up code a little bit
Test a few more things before deciding to switch to using SPI for display
Project page update for Hackaday and Trello
Clean things up a bit
Make things a little more consistent across platforms
Add photos and videos of project so far
Make a YT video?
Stream progress tomorrow on Twitch?
Other than the calibration of the magnetometer and gyroscope, learning Bluetooth programming, and the compass portion of the project, things are looking pretty smooth so far. Those are really the only speedbumps (as of this post) I'm facing currently. Especially the calibration of the magnetometer and gyroscope. I can't tell if I'm not finding the right resources or if I'm just implementing it wrong or something (probably a combination of both), but who knows, maybe some day in the future, I'll look back on these logs and laugh as it was just a simple thing I had not done yet. Same thing with Bluetooth, I just use the Adafruit learning guides, but don't really learn what these functions do other than the most vague of ideas.
I'm sure some of you out there are much smarter than me and have figured this stuff out already; in which case, please do let me know of any tips or tricks you may have for this kind of stuff, it is always appreciated as this is my first 'real' project. Alternatively, if you have any questions or comments on this project, let me know in the public chat! Until next post...
Technically, it began in October of 2021 when I planned out and ordered the parts for this project, but decided a complete rewrite, rewire, and redo was a much needed thing for this project to be somewhat feasible to finish. I started the rewrite yesterday by setting up a Trello board for the project. This would allow people to see active progress updates to the project without me having to write in here everyday (as fun as this is, it's much faster to drag and drop and type incomplete sentences). As far as this devlog goes, this wasn't really planned out to say anything in particular other than to say this is the official start of the project, there is a Trello board available to look at, and everything will hopefully be polished up within the coming week.
I have nothing else really to say, so thank you all for looking at my project. If you have any questions or comments, let me know in the public chat section and I'll be sure to read and reply to the best of my abilities.
