Dispensing faster and quieter
A project log for Nerdfeeder
Simple, inexpensive bird feeder that dispenses peanuts in exchange for dropping stuff in a hole.
Stephen ChaseyStephen Chasey 05/16/2022 at 16:090 Comments
I mounted the motor with hard drive magnets instead of bolts like before - this may be resulting in less agitation. Before I change this I will up the current to the motor and see if that works (or shakes it right off).
Also, the new enclosure is amplifying the vibration noise like a guitar body. I will try a silicone gasket (made from a silicone baking mat) to see if the reduces the noise a bit.
