I received my packaging materials today, so I packed up and shipped one to Warsaw for the student I mentioned a couple of updates ago.
This is what they will get:
I had to break it down a little for shipping (I included mounting hardware):
So it would fit in a 100x25x35cm box (weight 7kg):
I used soooo much bubble wrap - I hope it arrives in good condition.
UPDATE
They received it in good condition. Hopefully setup will go ok. I really want this to be easy to setup and use, so this is a good test.
UPDATE
After fixing a few connections that came loose in shipping, it seems to work and is mounted. Now it's up to the birds. Kudos to the student for some excellent troubleshooting and fixing.
Stephen Chasey
