New Enclosure and Mechanicals
A project log for Vending Machine for Birds
Simple, inexpensive bird feeder that dispenses peanuts in exchange for dropping stuff in a hole. A vending machine for clever birds.
stephen-chaseyStephen Chasey 10/21/2025 at 20:290 Comments
So I made the following improvements to the enclosure and internals.
I've tested it, but have left it turned off for now. I'll first turn it on and let it run on a day I can work from home to monitor it. It took a bit of tweaking to get everything to fit while keeping it simple.
Here's what it looks like now vs what it looked like before.
Now
Before
I tried using one of those pole mounts for lights and cameras, but in reverse. I got this for 11 EUR on Amazon.
It works prety well, but the feeder still needs a secondary point of support below the mount. I used a leftover bit of 110mm PVC pipe for this, but will hopefully think of a better way soon. If you are looking for hose clamps, sorry, I'm using all of them right now.
The enclosure is now basically 4 sections. Here they are, and the parts they're made of.
1. The deposit assembly.
2. The dispense platform
3. The electronics
I was too lazy to disassemble the camera arm - it consists of:
4. The hopper and dispenser
