PVC enclosure complete and mounted
A project log for Vending Machine for Birds
Simple, inexpensive bird feeder that dispenses peanuts in exchange for dropping stuff in a hole. A vending machine for clever birds.
stephen-chaseyStephen Chasey 08/22/2022 at 14:050 Comments
I finally finished the PVC-based enclosure and found a way to mount it on my weird balcony railing. The mounting uses pipe clamps to attach it to some wood beams. I found a wooden pallet by the trash and took one of the beams, and cannibalized my old wooden enclosure. For a vertical-barred railing you could use two horizontal beams instead of one vertical one.
For now I'm putting seed on the tray to get birds used to it again while I finish up other things.
Here's a brief look inside.
Peanut container (now loads from top!)
Vibration dispenser:
Dispensing funnel (top part of 1.5L PET bottle)
Deposit pathway
Deposit collector (bottom part of 1.5L PET bottle)
Now to resume putting the electronics on a solderable proto-board and fire it up again.
