Recore_A5 and Refactor 3.0.3 revision...
A project log for Recore and PrintrBot Mixtures
This is a Recore Board w/ a PrintrBot 1403 machine printer and... Now, I am using a Maker Select Plus w/ the Recore A7...
silver2rowsilver2row 04/27/2022 at 08:030 Comments
# Recore_1403 config
[recore]
revision: A5
gain_t0: 1
gain_t1: 1
gain_t2: 1
gain_t3: 1
pullup_t0: 1
pullup_t1: 1
pullup_t2: 1
pullup_t3: 1
#offset_t0: 0
#offset_t1: 0
#offset_t2: 0
#offset_t3: 0
# The STM32F031 mcu
[mcu]
serial: /dev/ttyS4
baud: 250000
restart_method: command
# The AR100 mcu
[mcu ar100]
serial: /dev/ttyS1
baud: 1500000
#[static_digital_output endstops_5V_enable]
#pins: ar100:PG11, ar100:PG8
# pin high = 12V, pin low = 5V
[static_digital_output endstop_ES0_5V_12V]
#[static_digital_output temperature_5V_enable]
#pins: ar100:PF1
#[static_digital_output over_current_alarm]
#pins: !ar100:PG1
[static_digital_output user_led_enable]
pins: PA12
#[static_digital_output enable_high_power]
#pins: !ar100:PG2
#[static_digital_output thermistor_pullups]
#pins: ar100:PD6, ar100:PD24, ar100:PF1
# Load "thermocouple" sensor
#[thermocouple]
[printer]
kinematics: cartesian
max_velocity: 500
max_accel: 3000
max_z_velocity: 25
max_z_accel: 10
[tmc2209 stepper_x]
uart_pin: ar100:PB1
tx_pin: ar100:PB0
uart_address: 0
run_current: 0.700
#hold_current: 0.500
#microsteps: 16
stealthchop_threshold: 250
driver_internal_rsense: 1
ref_resistor: 6800
[tmc2209 stepper_y]
uart_pin: ar100:PB1
tx_pin: ar100:PB0
uart_address: 1
run_current: 0.700
#microsteps: 16
ref_resistor: 6800
[tmc2209 stepper_z]
uart_pin: ar100:PB1
tx_pin: ar100:PB0
uart_address: 2
run_current: 0.700
#mircosteps: 16
ref_resistor: 6800
[tmc2209 extruder]
uart_pin: ar100:PB1
tx_pin: ar100:PB0
uart_address: 3
run_current: 0.700
#microsteps: 16
ref_resistor: 6800
[stepper_x]
step_pin: ar100:PL4
dir_pin: ar100:PE8
endstop_pin: ar100:PH5
rotation_distance: 35
microsteps: 16
position_endstop: 0
position_max: 152
homing_speed: 15.0
[stepper_y]
step_pin: ar100:PL5
dir_pin: ar100:PE9
endstop_pin: ar100:PH6
microsteps: 16
position_endstop: 0
position_max: 152
homing_speed: 15.0
# probe
[probe]
pin: ar100:PH4
z_offset: 0.20
x_offset: 0.0
y_offset: 0.0
[stepper_z]
step_pin: ar100:PL6
dir_pin: !ar100:PE10
endstop_pin: probe:z_virtual_endstop
#endstop_pin: !ar100:PH6
rotation_distance: 1.50
microsteps: 16
#position_endstop: 0
position_max: 152.0
homing_speed: 8.0
[extruder]
step_pin: ar100:PL7
dir_pin: ar100:PE11
heater_pin: PA9
sensor_type: EPCOS 100K B57560G104F
sensor_pin: PA1
microsteps: 16
nozzle_diameter: 0.375
filament_diameter: 1.75
control: pid
pid_Kp: 22.2
pid_Ki: 1.08
pid_Kd: 114
min_extrude_temp: 30
min_temp: 0
max_temp: 300
#[extruder1]
#step_pin: ar100:PL8
#dir_pin: ar100:PE12
#rotation_distance: 40
#microsteps: 16
#nozzle_diameter: 0.400
#filament_diameter: 1.75
#heater_pin: PA9
#sensor_pin: PA1
#sensor_type: RECORE PT1000
#control: pid
#pid_Kp: 22.2
#pid_Ki: 1.08
#pid_Kd: 114
#min_temp: 0
#max_temp: 300
#[extruder2]
#step_pin: ar100:PL9
#dir_pin: ar100:PE13
#microsteps: 16
#heater_pin: PA10
#sensor_pin: PA2
#sensor_type: PT100 INA826
#adc_voltage: 3.27
#control: pid
#pid_Kp: 22.2
#pid_Ki: 1.08
#pid_Kd: 114
#min_temp: 0
#max_temp: 300
#[heater_bed]
#heater_pin: PA11
#sensor_type: EPCOS 100K B57560G104F
#sensor_pin: PA3
#control: watermark
#min_temp: 0
#max_temp: 300
[fan]
pin: PB0
#[output_pin fan1]
#pin: PB1
#[output_pin fan2]
#pin: PB5
#[output_pin fan3]
#pin: PB4
# Set up board voltage, current, temperature.
[temperature_sensor board]
sensor_pin: PA6
max_temp: 110
gcode_id: Board
[temperature_sensor cold_junction]
sensor_pin: PA7
gcode_id: CJ
# Vout = Vin * 10K/110K = Vin*11
[adc_temperature v]
temperature1: 0.35
voltage1: 0
temperature2: 36.65
voltage2: 3.3
[temperature_sensor voltage]
adc_voltage: 3.3
sensor_pin: PA4
sensor_type: v
gcode_id: Voltage
# 1 A = 20 mV
[adc_temperature current]
temperature1: 0
voltage1: 0
temperature2: 165
voltage2: 3.3
[temperature_sensor current]
adc_voltage: 3.3
sensor_pin: PA5
sensor_type: current
max_temp: 20
gcode_id: Current
#[gcode_button over_current_alarm]
#pin: !ar100:PG1
#press_gcode: M112
