routing the 160 mm diameter hole
A project log for How to use an aerial 36 inches lens
the different steps involved to shoot with an aerial photographic (enormous) lens when you don't have the airplane to hold it
zit-olivier-gade[zit] Olivier Gade 04/27/2022 at 08:190 Comments
Using my little bench drill as a router, with an 2 mm tool, and a very small depth.
The size of the drill is just big enough to allow the plate to turn on it's central hole.
It's very long !
