accident
A project log for How to use an aerial 36 inches lens
the different steps involved to shoot with an aerial photographic (enormous) lens when you don't have the airplane to hold it
zit-olivier-gade[zit] Olivier Gade 04/27/2022 at 08:440 Comments
as you can see, there's a deviation of the line, I was pushing too hard and the vise holding plate of the drill has turned instead of the aluminium plate I was machining.
As it's the first pass, it's not very important, but from then, I had to hold the base plate with the left hand while turning the aluminium plate with the right one.
