The board material list
A project log for How to use an aerial 36 inches lens
the different steps involved to shoot with an aerial photographic (enormous) lens when you don't have the airplane to hold it
zit-olivier-gade[zit] Olivier Gade 04/27/2022 at 10:050 Comments
The 5 mm thick L profiles have been roughly cut to fit the circular shape, they already had exactly the good length.
2 holes that hold the lens are going to pass thru the 3 mm board and the 5 mm L profile on each side, 8 mm thickness should be good enough to hold the beast in place.
The 2 mm thick 3 cm square tube was bought on a garage sale, it's not as good quality as the other aluminium (the sidewalk high quality), but it will harden the assembly and will be convenient for the design of the hole thing.
