Carefully marking ​the holes.
A project log for How to use an aerial 36 inches lens
the different steps involved to shoot with an aerial photographic (enormous) lens when you don't have the airplane to hold it
zit-olivier-gade[zit] Olivier Gade 04/27/2022 at 10:130 Comments
Carefully marking the holes. The board color has little yellowish tint du to an anodization process, so chic.
