taping the rear of the board
A project log for How to use an aerial 36 inches lens
the different steps involved to shoot with an aerial photographic (enormous) lens when you don't have the airplane to hold it
zit-olivier-gade[zit] Olivier Gade 04/27/2022 at 14:260 Comments
Two 5 mm thick aluminium bars are needed on the back, to give more strength on both sides and to close the rear from light, to have the same thickness as the L profiles.
