Cutting the inside frame with a jigsaw.
A project log for How to use an aerial 36 inches lens
the different steps involved to shoot with an aerial photographic (enormous) lens when you don't have the airplane to hold it
zit-olivier-gade[zit] Olivier Gade 04/27/2022 at 16:040 Comments
Cutting the inside frame with a jigsaw. Very easy with an acrylic blade.
