First images
A project log for How to use an aerial 36 inches lens
the different steps involved to shoot with an aerial photographic (enormous) lens when you don't have the airplane to hold it
zit-olivier-gade[zit] Olivier Gade 04/29/2022 at 09:490 Comments
Yep, I'm that kind of photographer, slides, color transparencies is my practice, sometime developed like this, in positive E-6 chemicals, and sometimes, more often, developed in C-41 chemicals, to get a weird color negative.
And what I was fearing has happened : the first 10 pictures, taken with too much light for the f/16 aperture, are completely overexposed and blurry.
I augmented the contrast when developing the raw file, but there's not much to see.
Blurry and overexposed.
I should be more careful with the below, but that picture points a suspected trouble : the inner color of the below isn't as black as the outside, It's bluish, dark, but not black, I need to paint it black (as some other things to avoid parasitic reflections).
Ok, the ones shot later are much better, still a trouble with the below, but the lens looks good, event if it's a little blurry due to the opening of the film holder blind, the exposure is good and the details look sharp.
A 100 % crop of the previous image (this is not a real digitalisation of the picture, just a handheld shot) gives me good feeling about the results, the lights are not too burned, and it seems to have a good micro contrast, looking at it with a good magnifier is not the same sensation than on screen, its more detailed.
Well, I can continue the experiment, it is not a « cul de bouteille » (French for very bad optic), but now, I need to build a shutter.
