Second try, is the shutter fast enough ?
A project log for How to use an aerial 36 inches lens
the different steps involved to shoot with an aerial photographic (enormous) lens when you don't have the airplane to hold it
zit-olivier-gade[zit] Olivier Gade 05/31/2022 at 17:280 Comments
That television tower is at about 10 kilometers from home, the blur is mostly due to the air pollution.
This has been taken with the shutter of my Olympus camera.
This is with the shutter I made, it's much more blurry and at the fastest speed, not fast enough.
Let's try a closer easier to focus frame.
From the TV tower to the (much closer) TV antennas. (Olympus shutter 1/125 s.)
Nearly the same exposure value with my shutter, but... ok, the wind was very strong, but... something must be made to strengthen the system.
And the bungee string must be tightened to have a faster speed.
