Lens caps
A project log for How to use an aerial 36 inches lens
the different steps involved to shoot with an aerial photographic (enormous) lens when you don't have the airplane to hold it
zit-olivier-gade[zit] Olivier Gade 06/01/2022 at 10:550 Comments
Any lens, even the biggest ones, deserve a lens cap. The two circles remaining of the shutter frame are going to be perfect.
Milled with the 2 mm bit was very fast and easy.
Now the beast is secured.
Before, I had to, very, VERY carefully make the front opening round again with a nice hammer, as the lens might have felt on the floor because the brass surrounding had an impact mark and was deformed.
