Printed printon prints
A project log for Printon Turbine - 3D printed pelton turbine
A mostly 3D printed pelton turbine
fabianFabian 04/28/2022 at 16:320 Comments
I am currently waiting for the ordered components. So I can use the time perfectly to start and test the first 3D prints.
I am particularly curious if the seals between the 3D printed components are sufficient.
I would also like to check how well the flow can be regulated with the spear valve.
Here are a few photos of the currently printed parts. :)
This print took 18 hours. :D
One of the 3D printed buckets. I hope that this will withstand the water pressure.
