Prototype Testing!
A project log for Trick Tracker
ESP32 based data-logger for 9-Axis Accelerometer and Pressure
mirkoMirko 04/28/2022 at 17:480 Comments
Prototype was soldered!
All in all I am happy that at least most of the things are working. I have to make new Boards to fix the SD-Card but before I am running more tests.
I am running a battery life-time test. The device is running for 7h+ with one charge being connected to WiFi sending continous data to the cloud. That will be more then sufficient for the use-case. Somehow my code dies at around 35% Battery life which seems a bit weird. Once restarted it runs just fine but now and then stops for no reason. But that might be a different issue because the device stays connected to WiFi and is reachable - just not sure what might causing that.
