Sun Chaser 2 camera segmentation test.
04/30/2022 at 14:56 • 0 commentsImage segmentation is clustering parts of an image together that belong together. It is a game changer on projects like Sun Chaser. The below image is a test of Sun Chaser's segmentation. Below are two images from Sun Chaser 2’s camera. The green areas are areas where Sun Chaser thinks it can travel. The dark green areas are the shaded areas that Sun Chaser can travel. The light green areas are the high sunlight target areas.
Test for the highest light level.
04/30/2022 at 12:59 • 0 commentsOne of Sun Chaser’s main functions will be to find the area of the brightest light level. Two curved surfaces with six photo resistors are used to form a 360 degree light level direction indicator. The video below shows the test of the 360 degree light level sensors.
Dennis
