NeoPixel (WS2812B) Star
A Chrismas ornament or anything else you like!
I made this ornament a few years ago. It's made with 16 WS2812B, all the necessary capacitors and a diode/resistor combo for protection. Can be used for any special occasion!
I made this ornament a few years. It's made with 16 WS2812B, all the nesesary capacitors and a diode/resistor combo for protection. Can be used for any special occasion!
See build instructions for ideas!
  • 1 × WS2812B (NeoPixel) Star http://dirtypcbs.com/store/designer/details/5535/225/ws2812b-neopixel-star
  • 1 × BAT54S Dual Schottky Diode (optional)
  • 1 × 10uF / 16V Tantal
  • 1 × 330 ohm
  • 1 × 0.1uF Ceramic
  • 1
    Step 1
    This ornament can have a lot of uses. Chrismas is the prefered one:
    Christmas Wreath:
    As a wearable for Halloween:
    or for the Tooth Fairy!
    Tooth Fairy Demo (in French but you'll get the point!)Or any STUPID use that comes to your mind:
    PCB Layout
    The PCB layout outline with the pixels positions was made with SketchUp then exported as DXF and imported in EaglePCB.
View all instructions
Steve Michel wrote 04/22/2017 at 02:12 point
cool...nice design..perhaps we can use APA107 led source, more stable and cheap than sk6812, ws2812b, apa102 etc.
http://newstar-ledstrip.com/product/20180820112602493.pdf
zakqwy wrote 11/23/2016 at 15:22 point
Love the board layout!
Michel wrote 11/23/2016 at 17:47 point
Thank you! The PCB layout outline with the pixels positions was made with SketchUp then exported as DXF and imported in EaglePCB.
