[R][E1] Screens and build volume
A project log for SecSavr Suspense [gd0105]
The best of resin with the best of filament; is such a 3D printer possible?
kelvinakelvinA 06/21/2022 at 12:400 Comments
So having a next generation 3D printing technology is pretty cool, but having a next generation 3D printing technology in as many consumers' league budgets is a magnitude better. Thus, I wanted to research the CanDoTheTaskApp of using the 6.08" screen I've seen here-and-there while searching for usable screens on AliExpress.
Initial Screen Research
Unlike most screens, a variety of sellers were selling mono 6.08" screens. The cheapest I found was £27 yesterday and would probably work with this driver board, meaning that I didn't have to find some specific motherboard from a printer and then somehow get it to mesh with the rest of the system.
I believe this screen has a 50um pixel size.
So taking the dimensions above, I put an estimated build volume into Cura. The Z is 300mm, X is 82.6 * 4 = 330.4mm and Y is 130.5mm. Seeing if the Y axis is long enough is the experiment. I'd like the X axis to be around or over 300mm, so that's why I didn't use 82.6 * 3 = 247.8mm.
My idea is similar to the method that Formlabs describes in an article I found during my research.
It's like a hybrid between masking and lamination. For a bit of extra complexity, this solution allows the X axis length to be independent of the screen size and use a cheaper screen and light source to get a large print area. I'm not designing this for industrial use, so I think that the tradeoff of speed is worth it. It also means that the controller doesn't have to drive a screen with a high pixel count.
---------- more ----------
What fits?
An old foot design for my Anycubic Linear Plus.
A part of the Hexadecibel enclosure for the Anycubic Linear Plus.
An early Tetent concept.
A printable model of the OneNetbook OneGX1.
So I'm thinking "Hm... I can fit more in here than I expected. Surely not the front cover of the #Revolving Hotend [gd0012], right?".
The front cover of the Revolving Hotend.
"Noh. It can't be...", I thought, but it suprisingly does fit:
The enclosure box for the CR600S also fits in here.
This is when I tried that 3 screen width idea I dismissed earlier.
The leg of the CR600S that also integrates the screen and PSU socket.
Finally. Something that doesn't have a chance. This is a spool holder for 300mm spools and I probably wouldn't resin print this anyway. However, I saw that the longest side was only 150mm. The 7.6" screen on the Photon M3 has a 163.9mm edge, so I tried an X: = 63.9, Y = 102.4 * 3 = 307.2 build volume just to see what it would look like:
What are my other screen options?
6.6" 4K 35μm Mono
I went back to AliExpress to see what other screens the seller of the 6.08" had, and I found this nice sounding 6.6" 4K screen:
Oh hey, look, they've got a light source for this too!
Me Yesterday: W...what kind of light source is this?
Now the thing is that I'm new to the resin MSLA scene, so the only ones I've seen are the matrix array ones:
Since these kinds of light sources are in all the recent printers I've seen, and since it looks more complex, I assumed that these ones were better. Either way, I went to research the Elegoo Mars brand of 3D printers to see if there were any issues like the light being dim near the edges or lower sharpness, but I couldn't find anything. What I did find was this sponsored article on Creality's new Integral Light Source.
And I was able to find uniformity readings for both light sources:
Description of the light source from ChiTu.
Description of the light source used in the Elegoo Mars.
There doesn't seem to be a driver board for the 6.6" screen though.
8.9" 4K 50μm Mono
There's also an 8.9" screen, but the pixel size is the same so it would really only be a Y axis size increase to 192mm for a more expensive consumable (the screen) and light source.
Though, if I do go with this, I would like to call it the Suspense 360 because the X axis would be 120 * 3 = 360mm, and make it the larger edition alongside the Suspense; I'm currently struggling to find something that would actually need such a vast build volume.
Fitting figures
I'm not a mini figure person and would prefer a larger figure, say 35cm? Oh, shelves are 33cm height, so perhaps 32cm? So I scanned around the internet using yeggi to find some free models to see what would fit in the build volume if the Z height was 330mm+. There's not many but I found a few good ones.
Office Lady
Office Lady STL
Rotated my screen to Portrait, scaled the STL to 325mm and adjusted the zoom to get a more-or-less 1:1 representation. Then I stood on the other side of the room so that my mind actually saw it as if it existed IRL and I thought she was a good size, if maybe a tad tall. Oh and I finally reduced the saturation on the magenta material for added contrast.
Hatsune Miku
Miku Hatsune - Vocaloid
This is like the first model that actually stretches almost to the X axis limit. It's the Y axis that prevents the height from reaching 320mm, but it looked fine when scaled 1:1 so I moved on.
Aiz Wallenstein
Aiz Wallenstein
I scaled the file to the largest that the Y axis would allow and the model was around 280ish mm. I think "Hmm... She seems kind of... small." and switch to the Suspense360 build volume, scale Z to 320mm and then think "Yes. That's it. That's the Goldilocks zone size.".
But I felt like it would be a waste of print space to go all the way to an 8.9" screen, but it's likely that there are going to be other models with a round(ish) base that would benefit from a larger Y axis, such as this one:
Marquise Butterfly (Paid Model). This is also the kind of colour printing quality I want to target.
So then I look at the bounding box size:
"Hmm... 143... 143... where have I seen this number before?", I thought. It's the print size for the 6.6" 4K screen I found hours prior and almost forgot about.
A new day, a new conversation
So now it's 9am today and I continue talking to the seller (which I've shown below for anyone that would like to know the information) that just happens to have all this DIY MSLA kit.
This is excellent news. This screen has a 35um pixel size and both improves surface quality and is more likely to convincingly mix colours similar to inkjet due to a higher Pixel Per Inch count.
Here, I'm asking if I need to use a Fresnel lens like in the Mars 3.
Wait... You're saying that I can get more power for less money??
It indeed is cheaper and even shipping is lower. That brings the non-tax cost of the UV gear to around £123 without the current AliExpress discount.
Noticing that the DIY resin printer space is kind of... dry, I was really thinking that I was going to have to buy a Photon M3 for parts and then do some strange stuff to get the motherboard to work with the rest of the system.
So this both confirms that this kind of light source is better than the matrix array type, and a reason why an engineer would choose one over the other.
Finishing notes
It seems that the Suspense deliverable would have:
  • an XY build volume of 358.4 x 143.4mm and a Z height target of at least 330mm,
  • a XY resolution of 35 microns, which is an improvement over the Photon M3 / Max and comparable to the Mono 6K or M3 Plus,
  • a screen that would cost around £43 to replace (compared to the £66 Photon M3 screen as of writing), and
  • an exposure time that would be slightly less than the Elegoo Mars 3, meaning that parts that fit within a single screen area might print faster.
I'm thinking that a custom aluminium tool plate bed will be needed and hopefully it's just a case of drilling 4 holes to connect it to some mounting hardware. I don't have to worry about resin being able to drip off the underside. I also want the Z axis linear rails to be at the far edges of the build area's X axis so that I can have curing LEDs aimed at the middle of the build area were parts are more likely to be.
[Started writing log at 12:46. Published at 17:13]
[E1: 22 June, 23:34] This morning I asked the seller how much the 108W version was, and it's literally the $58 one I originally found. I was wondering why the heatsink looked larger than the 48W version. They just send a 24V 4.7A converter instead of a lower wattage one.Se49fe554313d4d3dbb9a776a7b35ce26H.jpg (563×1000)Looking at these exposure times for the Elegoo Mars 3 [see below], the fact that print times can be multiplied to as much as 4X, I can now use 24V for both the LED and motors and that the difference is only £10, I'm going with the 108W version.
