Vortex Layers Overview.mp419s clip showing the layers of the vortex bowl. This is from CAD and not a slicer.MPEG-4 Video - 2.15 MB - 04/18/2022 at 21:38 |
Standard Tesselated Geometry - 4.50 MB - 04/18/2022 at 16:50 |
Standard Tesselated Geometry - 3.88 MB - 04/18/2022 at 16:50 |
Standard Tesselated Geometry - 3.30 MB - 04/18/2022 at 16:50 |
Standard Tesselated Geometry - 2.99 MB - 04/18/2022 at 16:50 |
Standard Tesselated Geometry - 2.49 MB - 04/18/2022 at 16:50 |
Standard Tesselated Geometry - 2.01 MB - 04/18/2022 at 16:50 |
Vortex-3D Printable - Vortex Lid Inside Adapter.stlPrint 1 - This is the piece that goes inside the hole you have to cut in the lid of the 5 gallon (or other) bucket. It's intended to stick up through the hole from the bottom so the lip is on the inside of the bucket.Standard Tesselated Geometry - 317.00 kB - 04/18/2022 at 16:49 |
Vortex-3D Printable - Snap Arm.stlPrint 12 - This is the clip that goes in the catch on each side of each vortex slice. This means you'll need 12 of these.Standard Tesselated Geometry - 9.49 kB - 04/18/2022 at 16:49 |
