Outdoors Technology Test
A project log for Kite Propulsion
Harnessing the wind with robot controlled kites
ekEK 04/23/2022 at 13:580 Comments
On April 12th, I conducted an outdoors technology test. The purpose was to run through all the steps of setting up the experiment outdoors. The reason was to see what roadbumps occurred and why, in order for subsequent tests to be easier.
In the setup there is a green magic carpet to place all the equipment on, including an anemometer, laptop, mini tripod, camera, usb webcam, and two backpacks with additional items (such as bug spray). The laptop is running the KiteView software.
Winds were 10 km/h. The temperature reading on the anemometer is vastly incorrect, the temperature was more around 8 deg C.
Pairing the usb webcam and camera on the mini tripod together with tape.
Lessons learned:
The first lesson learned was really key, and this will be added to future outdoors tests.
The footage captured from this test was used to test KiteView software further and develop the kite tracking code.
Obligatory photo of kite flying :)
