Glass Tube Solar Thermionic Converters
Thermionic energy conversion isn't very efficient (it's also nothing new) but they *are* photovoltaic devices you can build with a torch
Thermionic energy converters produce electric power directly from heat by thermionic electron emission. Basically, they're heat engines. Unlike some other heat engines, like the Sterling Engines for instance, they have no moving parts! The first practical demonstration of thermionic conversion (a Caesium vapor arc-mode converter) was in 1957, and like many such devices, it was conscripted into space service. They were only ever deemed practical for nuclear power conversion, particularly in spacecraft (like surveillance satellites)
Thermionic converter research basically stopped until the 80s when groups started to explore "low temperature" thermionic converters using exotic fill-gasses and materials to increase emission, as well as suppress anode reflection. Today, there are groups researching this phenomenon in MEMS devices.
All of that said, I think there's more juice to squeeze out of this technology in its most basic (and accessible) form.
As I'm gearing up to make more traditional styles of vacuum tubes (diodes, triodes, VFDs) I'm going to have all of the equipment I need to build, evacuate, and test my own Solar Thermionic Conversion tubes. I know that they'll never be as efficient as silicon-based photovoltaics, but they have their own advantages. The fact that you can build them with a torch, a vacuum pump, and a spot welder (more or less) means that these are extremely accessible devices. There's no need to get your hands on doped silicon wafers or exotic dyes or spin-coating equipment (although, there are some great demonstrations of homemade silicon photovoltaic cells out there!) So it's possible for remote communities to manufacture these devices themselves.
I'm going to enter this into the Hackaday Prize running and if it gets any attention, I plan to build some functional units, test them, and make the method and construction open source. My focus won't be so much on efficiency as simplicity of production. Yes, I'd like to see how well this technology works when pushed to the limits of my lab, but once we have a working device, I want to see "how low can we go?" Can you build working converters with just a blowtorch and an old HVAC pump? Maybe not, but... maybe?
  • New New Backing Pump
    Nick Poole05/26/2022 at 02:28 1 comment
    I let the vacuum geeks talk me into a real backing pump and got this Welch 1402 for a good deal on eBay. The seller didn't know whether it worked, or what condition it was in. All they could say is that the motor runs and the pump feels like it pulls a vacuum. It looks good.
    Well... it looked good, until UPS got their hands on it...
    Luckily, the damage appears to be limited to the pulley and the oil mist filter. The seller offered to buy me a replacement pulley and so I found a used pulley of the same vintage and we got it sorted out. The new pulley arrives tomorrow.
    Before we can get this hitched to the turbo, we'll need to do a few things:
    • Flush the oil a few times and refill with fresh vacuum oil
    • Replace the pulley
    • Replace the belt
    • Adapt the inlet to KF25
    • Replace oil mist filter element and fix the cup or adapt the outlet to KF25 and replace with an Alcatel-style oil mist eliminator
    As soon as all of these things are done, I'll post an update. This should improve both our pump-down speed and ultimate vacuum, so it's worth the effort.
  • New Backing Pump and Turbo Pump Test
    Nick Poole05/09/2022 at 20:19 0 comments
    I finally acquired a TC gauge that would allow me to evaluate the roughing pump candidates and did some testing over the weekend. The diaphragm pumps that I have hoped to use were only able to achieve an ultimate vacuum of about 6 Torr.
    This is not horrible performance for a diaphragm pump, and it's also within the safe operating range for the Edwards EXT255H compound turbo pump, but there are a few reasons I'm not happy with it. Firstly, there just isn't much margin and working with such a high backing pressure will put more wear on the turbo pump than is necessary. Secondly, the Pirani gauges that I planned on using for monitoring rough-down and process control just don't operate at pressures that high. It would be much better to achieve a foreline pressure of at least 0.5 Torr so that the Pirani gauges can register it. To that end, I bought a Harbor Freight refrigeration service pump to act as my backing pump. I had hoped to keep the system entirely oil-free, but with some basic precautions, it should be very difficult for pump oil from the roughing pump to contaminate the rest of the system.
    With the test manifold assembled, I fired up the new roughing pump and within a few minutes got the foreline pressure down below 0.1 Torr which is a massive improvement. With that settled, I wired up the Turbo and ion gauge, tightened everything down, and ran the whole system down for the first time.
    As you can tell from the glowing ion gauge, the system pumped down just fine and within about 20 minutes we were moving down through 10⁻⁵ mbar!
    That's good enough. More performance can be squeezed out here by properly cleaning and drying the whole system and putting some Faraday Wax over the damaged purge valve port on the side of the turbo, but even if we never get into the 10⁻⁷ territory, a getter material in the sealed tubes will clean up the rest.
  • Gearing Up to Pump Down
    Nick Poole04/25/2022 at 20:12 0 comments
    These Solar Converters are only a small diversion in the larger project of experimenting with vacuum tube devices at home. To that end, I'm already in the process of building a high vacuum system that will be more than capable of pulling these tubes down to the levels of vacuum required to work. I'm also putting together the glass-working tools that will be needed to fabricate the envelopes and feedthroughs. I thought it would be nice to post some pictures of my growing stack of vacuum equipment here!
    Here you can see my gauge controller and a number of vacuum gauges: two Edwards Pirani gauge heads and a Duniway Stockroom ion gauge. I've also put together a bunch of vacuum plumbing, although like any good plumbing project, I'm still missing some fittings. In the lower left, you can get a small peek of the mechanical vacuum pump that I planned to use. Unfortunately, even though it was sold to me as possibly being a Pfeiffer MVP series pump, it appears to be a Vacuubrand MZ, which I might get away with because of my choice of turbo pump (more on that in a second) but I'm also waiting on another pump to arrive which should reach much more convincing levels of backing pressure.
    The big succboy is an Edwards EX255H compound pump which was pulled from a working mass spectrometer. It came with the controller, so I just need to provide it with 24V and it will do the rest. It has all of the modern self-protection features and tolerates a continuous working foreline pressure up to 5 mbar(!) although I hope to be able to achieve better than that.
    I'll post another project log when we achieve first pump-down. Right now the main hold-up is an ISO-K 100 to KF16 reducer that I had to order from China. In the meantime, I'll be sorting out my roughing pump and plumbing.
  • Proof of Concept Pt.2
    Nick Poole04/21/2022 at 00:25 1 comment
    So we know that we can get some open circuit voltage by heating the cathode, but can it do any work?
    Here, two 6v3a diodes in series light an LED with their filaments at full tilt. The LED is drawing 7.5uA at 1.7v (LEDs are incredible)
    Rough napkin math puts these diodes at about a 0.00012% conversion efficiency. That's between 5 and 6 orders of magnitude worse than a commercial PV cell. That said, these diodes are obviously not designed as thermionic converters.
    As a demonstration, it feels a little "so what" until you unplug the power and the LED keeps shining until the cathodes cool down. That's neat.
  • Proof of Concept?
    Nick Poole04/20/2022 at 18:22 0 comments
    Please enjoy this short video of me going ham on this poor 6v3a diode tube
    In this video I'm using a large double-convex lens to heat up the cathode of a 6v3a diode to stimulate emission. Because these were designed to be heated from inside with a filament, the cathode doesn't really have line-of-sight to the outside of the envelope, but there is enough protruding through the top mica that I was able to get a bead on it. Considering this tube is not optimized for conversion, half a volt of open-circuit voltage is more than I was expecting. Of course there's almost no current available, and if you were to leave it this way it would eventually fail as the anode heated up and began emitting (or the envelope would eventually shatter) because there's no cooling.
    That said, there it is, glass tube solar thermionic conversion!
  • A niche within a niche
    Nick Poole04/20/2022 at 18:15 0 comments
View all 6 project logs
Jo Verbeeck wrote 04/27/2022 at 20:23 point
lowering work function of the filament could also change things even though there are not many accessible materials that can do this. Also uv light will be more likely to overcome the work function but most of that is now stopped by the glass envelope. Getting over say 3-5eV of work function with thermal energy kBT is indeed very unlikely unless T is very high.
Boris van Galvin wrote 04/25/2022 at 20:26 point
Nice project. At the moment I am trying to find a way to capture the heat from the ground on a volcano. its about 50 to 60deg C and the air is between -10 to -40 degC The thoughts are to use Peiltier's or TEG's to harness power and try and recharge the battery/run the sensors.
Kyle Brinkerhoff wrote 04/25/2022 at 14:06 point
I suspect that these could be made to work much more efficiently with a voltage potential present in the system, basically relying on photons for the activation potential, you will need to significantly raise the voltage floor to have sufficient activation, but then the question is, how do I efficiently drive a HV source to then eek out that little bit of extra juice I get from photon interaction ?
Nick Poole wrote 04/25/2022 at 19:57 point
I suppose you could also introduce ionizing radiation sources to lower the activation energy
