A niche within a niche
A project log for Glass Tube Solar Thermionic Converters
Thermionic energy conversion isn't very efficient (it's also nothing new) but they *are* photovoltaic devices you can build with a torch
nick-pooleNick Poole 04/20/2022 at 18:150 Comments
As I'm gearing up to make more traditional styles of vacuum tubes (diodes, triodes, VFDs) I'm going to have all of the equipment I need to build, evacuate, and test my own Solar Thermionic Conversion tubes. I know that they'll never be as efficient as silicon-based photovoltaics, but they have their own advantages. The fact that you can build them with a torch, a vacuum pump, and a spot welder (more or less) means that these are extremely accessible devices. There's no need to get your hands on doped silicon wafers or exotic dyes or spin-coating equipment (although, there are some great demonstrations of homemade silicon photovoltaic cells out there!) So it's possible for remote communities to manufacture these devices themselves.
I'm going to enter this into the Hackaday Prize running and if it gets any attention, I plan to build some functional units, test them, and make the method and construction open source. My focus won't be so much on efficiency as simplicity of production. Yes, I'd like to see how well this technology works when pushed to the limits of my lab, but once we have a working device, I want to see "how low can we go?" Can you build working converters with just a blowtorch and an old HVAC pump? Maybe not, but... maybe?
