Key Components Part 1: Bus, Microprocessor and Memory Controller.
A project log for BoxLambda
A retro-style FPGA-based microcomputer. The microcomputer serves as a platform for software and RTL experimentation.
EpsilonEpsilon 04/23/2022 at 17:080 Comments
In the previous post, we discussed top-level requirements. Now we drill down one level, identify key components and apply our requirements to them. We also look around for existing cores or applicable specs that might fit the bill.
The Bus
The Bus, or interconnect, is the fabric stitching together the SoC internal components. For this project, the two most relevant SoC internal bus specifications are ARM’s AXI bus and the Open-Source Wishbone bus.
AXI is very powerful, very popular, and very complex. It scales up well to very big SoCs. However, I don’t think it scales down very well to simple SoCs, such as BoxLambda, where low latency and low complexity are more important than high bandwidth and scalability. Hence, for this project, I’m electing to go with Wishbone.
We’ll be using the Wishbone B4 specification.
Sticking to a well-defined internal bus specification certainly helps to meet the Modular Architecture Requirement. Whether we can also accommodate Partial FPGA Reconfiguration using a Wishbone Interconnect remains to be seen.
The Processor
Processor Word Size
Typical processor word sizes are 8-bit, 16-bit, 32-bit, and 64-bit. Which word size is the best fit for Boxlambda?
I’ve decided to go for a 32-bit processor. A 32-bit processor (and associated on-chip memory) will take a bigger chunk out of our FPGA real estate, but I think it’s worth it. I like the convenience of 32-bit registers, and a 32-bit processor may come with a regular GCC toolchain.
Processor Features
Next to a 32-bit word size, we’re looking for the following features for our microprocessor:
With all that in mind, I think RISC-V is a great option.
There are a lot of RISC-V implementations to choose from. The Ibex project seems like a good choice:
The Memory Controller
SDRAM memory access is pretty complicated. Memory access requests get queued in the memory controller, scheduled, and turned into a sequence of commands that vary in execution time depending on the previous memory locations that were recently accessed.
There exists a class of memory controllers, called Static Memory Controllers, that absorb these complexities and by design create a fixed schedule for a fixed use case, resulting in very predictable behavior. Static Memory Controllers are far off the beaten path, however. Dynamic Memory Controllers are more common. Dynamic Memory Controllers can handle a variety of use cases with good performance on average. Unfortunately, they sacrifice predictability to achieve this flexibility.
Ideally, we would use an accessible, well-documented, open-source, static memory controller design. Unfortunately, I can’t find one. Rolling our own is not an option either. Doing so would require so much specific know-how, that it would kill this project. Pragmatically, our best option is to use Xilinx’s Memory Interface Generator (MIG) with the Arty A7 (or Nexys A7) parameters as published by Diligent.
The Xilinx memory controller falls squarely into the Dynamic Memory Controller class. How do we fit this into a platform that requires deterministic behavior? I think the best approach is to use a DMA engine to transfer data between SDRAM and on-chip memory. Fixed memory access latency to on-chip memory (from any bus master that requires it) can be guaranteed using an arbiter. We’ll revisit this topic when we’re discussing Boxlambda’s architecture.
Interesting Links
A nice intro to RISC-V Assembly Programming
