Interrupts, and estimated FPGA Resource Utilization.
A project log for BoxLambda
A retro-style FPGA-based microcomputer. The microcomputer serves as a platform for software and RTL experimentation.
EpsilonEpsilon 05/29/2022 at 09:060 Comments
Our CPU supports the following interrupts (taken from https://ibex-core.readthedocs.io/en/latest/03_reference/exception_interrupts.html):
Ibex Interrupts:
Interrupt Input Signal ID Description
irq_nm_i 31 Non-maskable interrupt (NMI)
irq_fast_i[14:0] 30:16 15 fast, local interrupts
irq_external_i 11 Connected to platform-level interrupt controller
irq_timer_i 7 Connected to timer module
irq_software_i 3 Connected to memory-mapped (inter-processor)
interrupt register
The Timer
The RISC-V spec includes a timer specification: RISC-V Machine Timer Registers (see RISC-V Privileged Specification, version 1.11, Section 3.1.10). The Ibex GitHub repository contains a compliant implementation as part of the Simple System example:
https://github.com/epsilon537/ibex/tree/master/examples/simple_system
We’ll be using this timer module implementation, so we don’t need a separate PIT module.
The Timer module flags interrupts via signal irq_timer_i. The CPU sees this as IRQ ID 7.
The Fast Local Interrupts
We can freely assign 15 local interrupts. I’ve got the following list:
The interrupts are serviced in order of priority, the highest number being the highest priority.
I have ordered the Fast Local interrupts as follows:
Fast Local Interrupt Assignments:
irq_fast_i[14] 30 RM_2 interrupt (Default: not assigned)
irq_fast_i[13] 29 RM_1 interrupt (Default: VERA IRQ)
irq_fast_i[12] 28 RM_0 interrupt (Default: not assigned)
irq_fast_i[11] 27 Praxos DMAC IRQ
irq_fast_i[10] 26 sdspi IRQ
irq_fast_i[9] 25 wbuart IRQ
irq_fast_i[8] 24 ps2_keyboard IRQ
irq_fast_i[7] 23 ps2_mouse IRQ
irq_fast_i[6] 22 sbi2c IRQ
irq_fast_i[5] 21 GPIO IRQ
irq_fast_i[4] 20 Quad SPI IRQ
irq_fast_i[3] 19 DFX Controller IRQ
irq_fast_i[2] 18 ICAP IRQ
irq_fast_i[1] 17 not assigned
irq_fast_i[0] 16 not assigned
The Platform Level Interrupt Controller.
One interrupt line is reserved to connect an external interrupt controller. I don’t have any use for it right now, however, so I’m going to leave this unassigned for the time being.
Since we currently don’t have a use for the Programmable Interrupt Controller, I’ll remove it from the Architecture Diagram.
Will It Fit? Estimated FPGA Resource Utilization.
I could keep adding modules and dream up architectures all day long, but some kind of reality-check is long overdue. I’m going to create a fork of all modules identified so far and run them through synthesis, as-is, just to get a sense of the resource utilization on the Arty A7-35T and the Nexys A7-100T. We won’t get more than ballpark figures out of this, but that’s all we need right now.
Synthesis
Synthesis is handled by Vivado, Xilinx’s FPGA Design Suite. Vivado is free to download: https://www.xilinx.com/products/design-tools/vivado/vivado-ml.html.
The synthesis tool turns a module’s Verilog/System Verilog/VHDL source code into a netlist of gates. In the process of doing so, the tool also generates a utilization report, relative to the available resources of the target FPGA. It’s this utilization report we’re after right now, not the generated netlist.
Here’s an example utilization report, generated during the synthesis of the MIG core:
https://github.com/epsilon537/boxlambda/blob/main/doc/mig_7series_0_utilization_synth.rpt
For most of the cores, synthesis was just a matter of pointing Vivado to the core’s source tree and hitting the Run Synthesis button. There were a few exceptions:
ibex_top.sv:
    parameter rv32m_e      RV32M            = RV32MFast,
    parameter rv32b_e      RV32B            = RV32BBalanced,
I organized the utilization numbers from the different cores into a table and compared them to the available resources on the Nexys A7-100T and the Arty A7-35T. The results are shown below.
Nexys A7-100T Estimated Utilization
BoxLambda Estimated FPGA Resource Utilization on Nexys A7-100T:
Resources Type DPRAM Vera Ibex RV32IMCB MIG Dual JT49 Praxos DMA ps2 keyb. ps2 mouse
Slice LUTs 0 2122 3390 5673 554 380 205 205
Slice Registers 0 1441 911 5060 622 167 185 185
Block RAM Tile 64 41 0 0 1 0.5 0 0
DSPs 0 2 1 0 0 0 0 0
Resources Type sdspi wbi2c wbuart Quad SPI Margin Pct. Total (incl. margin) Avl. Resources Pct. Utilization
Slice LUTs 536 393 438 440 20.00% 17203.2 63400 27.13%
Slice Registers 324 114 346 641 20.00% 12757.2 126800 10.06%
Block RAM Tile 1 0 0 0 20.00% 129 135 95.56%
DSPs 0 0 0 0 20.00% 3.6 240 1.50%
I added a 20% margin overall for the bus fabric and for components I haven’t included yet.
Overall it’s an easy fit, with room to spare. All the pressure is on the Block RAM. Slice utilization (registers and combinatorial logic) is low.
Arty A7-35T Estimated Utilization
BoxLambda Estimated FPGA Resource Utilization on Arty A7-35T, before adjustment:
Block RAM Tile 32 25 0 0 1 0.5 0 0
Slice LUTs 536 393 438 440 20.00% 17203 20800 82.71%
Slice Registers 749 324 346 641 20.00% 12757 41600 30.67%
Block RAM Tile 1 0 0 0 20.00% 71 50 142.80%
DSPs 0 0 0 0 20.00% 4 90 4.00%
On the Arty A7-35T it’s a tight fit. Actually, the Block RAM doesn’t fit at all. If we reduce the amount of DPRAM to 64KB and reduce the margin on Block RAM to 10%, we can just make it fit:
BoxLambda Estimated FPGA Resource Utilization on Arty A7-35T, after adjustment:
Block RAM Tile 16 25 0 0 1 0.5 0 0
Block RAM Tile 1 0 0 0 10.00% 48 50 95.70%
Slice utilization is also fairly high. This might lead to some routing issues down the line. Still, these numbers are good enough to keep the Arty A7-35T in the running for the time being, at least as a kind of development/prototyping platform. I’m not ready yet to spend the cash on a Nexys A7-100T.
Architecture Diagram Updates
Based on these synthesis results, I settled on the following modifications to the architecture diagrams:
Nexys Draft Architecture Block Diagram
BoxLambda Draft Architecture Block Diagram for Nexys A7-100T.
Arty Draft Architecture Block Diagram
BoxLambda Draft Architecture Block Diagram for Arty A7-35T.
https://www.linusakesson.net/scene/parallelogram/index.php: Linus Akesson once made an FPGA-based demo. To do that, he created an FPGA-based computer, with a homegrown CPU, shader, and synthesizer. When I grow up, I want to be as cool as Linus Akesson.
