On USB HID, Keyboard LEDs, and device emulation.
03/12/2024 at 16:37 • 0 comments -
The Interconnect, Harvard Architecture, and Dual Port RAM.
01/06/2024 at 12:09 • 0 comments -
An attempt at a PicoRV32-based Soft DMA Controller - Optimizations.
11/14/2023 at 12:00 • 0 comments -
An attempt at a PicoRV32-based Soft DMA Controller.
10/21/2023 at 08:40 • 0 comments -
Chiptunes! A Dual YM2149 PSG Audio core for BoxLambda.
08/19/2023 at 11:49 • 0 comments -
Post-Implementation Memory Updates.
06/18/2023 at 13:55 • 0 comments -
Bringing up the SD-Card Controller and File System.
05/12/2023 at 13:05 • 0 commentsI added an SD-Card Controller and File System to BoxLambda:
Integrating VERA
04/20/2023 at 12:25 • 0 commentsI integrated the VERA Versatile Embedded Retro Adapter into the BoxLambda SoC. The Blog post below discusses the changes I made to the VERA core to interface it with a 32-bit system.
Building Software and Gateware with CMake and Bender.
02/14/2023 at 21:39 • 0 commentsRecap
This is a summary of the current state of affairs for BoxLambda. We have:
- An Ibex RISC-V core, a Wishbone shared bus, a Debug Core, internal memory, a timer, two GPIO ports, and a UART core.
- A Picolibc-based standard C environment for software running on the Ibex RISC-V core.
- Test builds running on Arty-A7-35T and Verilator.
- Automated testing on Verilator.
- OpenOCD-based Debug Access, both on FPGA and Verilator.
- A Linux GNU Makefile and Bender-based RTL build system.
- DDR3 external memory access through the Litex Memory Controller.
The Case for CMake
Around the time I integrated Picolibc into BoxLambda it became clear that I needed to invest a bit more energy in BoxLambda’s build system. The build system was based on a simple set of GNU Make rules and Bender manifests. It worked reasonably well for Verilator and FPGA synthesis, but there were a few limitations that were starting to hurt. Specifically, I wanted to add the following features to the build system:
- Proper dependency tracking for software: The old build system used forced build rules. Every software build was a full rebuild. The improved build system should use incremental builds with proper dependency tracking from memory files to executables, to libraries, and sources.
- Proper dependency tracking for RTL: Implementation and bitstream generation depends on synthesis. Synthesis depends on HDL sources, constraints files, and memory files. Memory files depend on software.
- Out-of-Tree build trees: Out-of-Tree build trees are way more convenient than In-Tree build trees. You can create as many of them as you want, they’re easy to remove when you no longer need them, and the derived objects don’t clutter up your source tree.
- Support for build options: I want to be able to specify whether the build tree is to be used for simulation builds, or for FPGA synthesis.
- Support for different FPGA targets: Arty-A7-35T and Arty-A7-100T to begin with.
I thought this would be a good opportunity to try out Meson, a modern build system generator with a clean, elegant python-like syntax. The Meson experiment came to a halt pretty quickly, however. I just couldn’t get my head around the fact that the Meson DSL does not include functions or macros. I ended up with a bunch of virtually identical meson.build files because I didn’t have a way to abstract common patterns. You can take a look at BoxLambda’s meson branch if you’re interested.
I decided to switch over to CMake. Compared to Meson, CMake has a more cluttered, messy syntax, but it is more flexible. It has functions, macros, and all the other goodies you can expect of a build system generator:
- Easy dependency tracking.
- Support for Out-of-Tree builds.
- Support for build options.
- Support for automated testing.
- Configure-Time source code generation.
This is the first time I’m using a build system generator. I always got by with GNU Make itself. Now that I that I tried CMake, I have to say that I like it a lot. It’s almost like going from assembly language to C. I probably could have implemented all the build system features I wanted directly in GNU Make, but it’s so much easier in CMake.
Sidenote: Gateware
I first encountered the term Gateware in the LiteX project.
I think the term covers its meaning very well and it’s the perfect counterpart for software. I’ll be using it from here on out.
The Directory Structure
<BoxLambda Root Directory> ├── boxlambda_setup.sh ├── CMakeLists.txt ├── sub/ │ └── <git submodules> ├── gw/ │ ├── CMakeLists.txt │ ├── components/ │ │ ├── CMakeLists.txt │ │ ├── wbuart32/ │ │ │ ├── rtl/ │ │ │ ├── CMakeLists.txt │ │ │ └── Bender.yml │ │ └── <other gw component directories> │ └── projects/ │ ├── CMakeLists.txt │ ├── ddr_test/ │ │ ├── constr/ │ │ ├── rtl/ │ │ ├── sim/ │ │ ├── CMakeLists.txt │ │ └── Bender.yml │ └── <other gw project directories> ├── sw/ │ ├── CMakeLists.txt │ ├── components/ │ │ ├── CMakeLists.txt │ │ └── <sw component directories> │ └── projects/ │ ├── CMakeLists.txt │ ├── ddr_test/ │ │ ├── CMakeLists.txt │ │ └── <ddr_test sources> │ └── <other sw project directories> └── build/ ├── sim/ ├── arty-a7-35/ └── arty-a7-100/
I made some changes to BoxLambda’s directory structure:
- I separated the software tree (sw/) from the gateware tree (gw/).
- The build trees (build/) are separate from the sw and gw source trees
The build trees are CMake build trees generated by the boxlambda_setup.sh script. As you can see in the tree diagram above, the script generates three build trees: one for simulation, one for the Arty-A7-35T, and one for the Arty A7-100T. The build trees are not under version control.
Building Gateware
Assuming all Prerequisites are installed, navigate to the build tree of choice and type:
make <gw component or project name>_<action>
where action is one of the following:
- lint: Lint-check the given gateware component or project.
- sim: Build the Verilator simulation model (Vmodel) of the given gateware project. This action only exists in the sim/ build tree.
- synth: Synthesize the given gateware component or project. This action only exists in the arty-a7 build trees.
- impl: Implement the given gateware project and generate its bitstream. This action only exists in the arty-a7 build trees.
- load: Load the gateware project’s bitstream file onto the connected target. This action only exists in the arty-a7 build trees.
Some examples:
cd <boxlambda_root_dir>/build/sim && make ddr_test_sim
cd <boxlambda_root_dir>/build/arty-a7-35 && make hello_world_synth
cd <boxlambda_root_dir>/build/arty-a7-100 && make hello_dbg_impl && make hello_dbg_load
The build directory tree mimics the source tree. When a build has been completed, a gateware project’s Verilator model or the Vivado project files can be found under that project’s directory. E.g.:
$ cd build/arty-a7-35/gw/projects/hello_world $ make hello_world_synth ... $ ls CMakeFiles hello_world.constraints_file_list project.cache project.runs syn_util.rpt CTestTestfile.cmake hello_world.mem_file_list project.dep project.xpr Makefile hello_world.vivado_sources project.hw spram.mem cmake_install.cmake hello_world.vivado_sources.dep project.ip_user_files syn_timing.rpt
What happens when you run make hello_world_synth
When you run make hello_world_synth, the following happens:
- Make determines if (re)synthesis is needed. If synthesis is up-to-date, no further action is taken.
- Make runs a bender script command on the bender.yml file in the gw/projects/hello_world/ directory. The bender script command is wrapped in the scripts/bender_gen_vivado_source.sh shell script.
- The bender script command processes that bender.yml manifest, as well as the bender.yml manifests of any dependent components.
- The bender script command emits a list of all the HDL sources that make up the project.
- Similarly, the scripts/bender_gen_constraints_file_list.sh and scripts/bender_gen_mem_file_list.sh emits the .xdc constraints and .mem memory files for the project.
- Make feeds these file lists into a vivado_create_project.tcl script.
- The vivado_create_project.tcl script creates a Vivado project.
- Make kicks off the vivado_synth.tcl script which opens the Vivado project and starts synthesis.
When you run make hello_world_impl, the following happens:
- Make determines if (re)implementation and bitstream generation is needed. If the bitstream file is up-to-date, no further action is taken. Make will also run the hello_world_synth rule above because it’s a dependency of hello_world_impl.
- Make kicks off the vivado_impl.tcl script which opens the Vivado project, picks up the synthesis checkpoint, and starts implementation.
See the BoxLambda documentation Bender section of for more info on how BoxLambda uses Bender.
Building Software
The software corresponding with a gateware project automatically gets compiled, converted to a memory file, and included in the gateware project as part of the build process. Software projects can also be built independently. From the build directory just type:
make <sw project name>
. For example:$ cd sim/sw/projects/hello_world/ $ make hello_world ... $ ls CMakeFiles Makefile hello_world hello_world.map CTestTestfile.cmake cmake_install.cmake hello_world.hex hello_world.mem
Make All, Clean, and Regen
make all
will lint check and build ‘impl’ all gateware projects.make clean
in a build tree will remove all the generated files that the build system is aware of. The generated files the build system is not aware of, e.g. synthesis utilization report files, will not be removed, however. If you want to go back to a completely clean build tree, typemake regen
from the build directory. This command will completely remove and regenerate the build tree.Creating additional build trees
You can easily create additional build trees from the BoxLambda root directory with the following command:
cmake --preset=sim|arty-a7-35|arty-a7-100 -B <build directory>
For example:
cmake --preset=sim -B build/sim2
Running Regression Tests
CMake comes with a regression test framework called Ctest. BoxLambda regression tests are only defined in a simulation build tree. To see a list of available test cases, you need to first build everything and then run a
ctest -N
command to list the test cases:cd <boxlambda root dir>/build/sim make all ctest -N
You should see something like this:
Test project /home/epsilon/work/boxlambda/build/sim2 Test #1: hello_world_test Test #2: hello_dbg_test Test #3: picolibc_test_test Test #4: ddr_test_test Total Tests: 4
To run a specific test, run the following command from the build directory:
ctest -I <test number>
To run all tests, just run the ctest command without any parameters.
The CMakeLists
The build system consists of a tree of CMakeLists.txt files: The top-level CMakeLists.txt adds the gw/ and sw/ subdirectories. The CMakeLists.txt files in those subdirectories add the components/ and projects/ subdirectories, etc., down to the individual GW and SW component and project directories.
A Gateware Component CMakeList
The build instructions for a gateware component are grouped into one CMake function: gw_component_rules(). A GW component-level CMakeLists.txt file contains just a call to this function, passing in the expected parameters:
gw_component_rules( TOP_MODULE <top module name> COMPONENT_NAME <component name> )
For example:
gw_component_rules( TOP_MODULE wb_wbuart_wrap_wrap COMPONENT_NAME wbuart32 )
The component’s sources, definitions, and dependencies are still defined in its bender.yml manifest. The CMake build system interfaces with Bender through a set of scripts to extract the necessary info and pass it on to Vivado or Verilator.
A Gateware Project CMakeList
The build instructions for a gateware project are also grouped into a CMake function: gw_project_rules(). This function has a few additional arguments compared to its component counterpart. A typical GW project CMakeLists.txt file looks like this:
gw_project_rules( TOP_MODULE <top module name> PROJECT_NAME <project name> MEM_FILE_TARGET <sw project name> MEM_FILE_OUT <name of memory file expected by the SoC build. Currently, all project builds use spram.mem.> VERILATOR_CPP_FLAGS <Verilator CPP flags, e.g. include paths> VERILATOR_LD_FLAGS <Verilator link flags, e.g. -lncurses> ) #Add testcase. add_test(NAME <test name> COMMAND <test command> WORKING_DIRECTORY ${CMAKE_CURRENT_BINARY_DIR} )
For example:
gw_project_rules( TOP_MODULE ibex_soc PROJECT_NAME hello_world MEM_FILE_TARGET hello_world MEM_FILE_OUT spram.mem VERILATOR_CPP_FLAGS "-I${PROJECT_SOURCE_DIR}/sub/wbuart32/bench/cpp/" VERILATOR_LD_FLAGS "-lncurses" ) add_test(NAME hello_world_test COMMAND ./Vmodel WORKING_DIRECTORY ${CMAKE_CURRENT_BINARY_DIR} )
As is the case for GW components, the project’s sources, definitions, dependencies, and constraint files are defined in its bender.yml manifest. The reference to the SW project delivering the memory file is not defined in the Bender manifest, however. The SW project name is passed in as the MEM_FILE_TARGET parameter in the gw_project_rules() call.
Any test cases are also added to the project’s CMakeLists.txt file.
Software Build Structure
CMake is designed to build software. The necessary functions for creating libraries, executables, etc. are predefined. The only custom function added to the software CMakeLists tree is link_internal_create_mem_file(). This function implements the necessary instructions to link the given executable against the BoxLambda internal memory map and generate a memory file, to be used by the GW part of the build system.
A typical SW project CMakeLists.txt file looks like this:
add_executable(hello_world EXCLUDE_FROM_ALL ../../../sub/ibex_wb/soc/fpga/arty-a7-35/sw/examples/hello/hello.c ../../../sub/ibex_wb/soc/fpga/arty-a7-35/sw/libs/soc/gpio.c ../../../sub/ibex_wb/soc/fpga/arty-a7-35/sw/libs/soc/utils.c ) target_compile_options(hello_world PRIVATE -g) link_internal_create_mem_file(hello_world)
Implementation
CMakeLists Organization.
The actual gateware build recipes (Bender interaction, verilating, synthesizing…) are implemented by a set of bash and tcl scripts kept in the scripts/ directory:
bender_gen_constraints_file_list.sh bender_gen_verilator_sources.sh bender_gen_vivado_sources.sh bender_get_cpp_files.sh bender_get_vlts.sh gen_mem_file_list.sh prg_bitstream.tcl verilator_lint_check.sh verilator_sim.sh vivado_create_project.tcl vivado_impl.tcl vivado_synth.tcl
Having the build recipes as scripts instead of CMake allows me to invoke and test them outside of the build system.
The CMake build instructions define the various targets and the relationships between them, and invoke the above build scripts when needed.
The CMake build definitions are located as close as possible to the part of the tree to which they apply, e.g. the gw_project_rules() function can be found in the gw/projects/CMakeLists.txt file. Gw_component_rules() can be found in the gw/components/CMakeLists.txt file. Gateware build instructions common to components and projects are located in the gw/CMakeLists.txt file.
Cross-Compilation
RISC-V cross-compilation is set up by passing in a toolchain file to CMake. The toolchain file is located in scripts/toolchain.cmake.
Picolibc GCC specs file
The Picolibc GCC specs file expects absolute paths. I’m using CMake’s configure_file() to replace placeholders in scripts/picolibc.specs.in with the project source directory’s absolute path. The resulting picolibc.specs is written in the root of the build tree. This way, the Picolibc library build for BoxLambda can be checked into the source tree and the user won’t need to build and install it from source when setting up BoxLambda.
Bender Interaction Hack
GNU Make, CMake’s backend, uses the modification date of dependencies to decide if a build rule should be triggered, e.g. an object gets rebuilt when the corresponding source code has a more recent modification date than the object file itself. With Bender, however, a component’s or project’s bender.yml file is just the tip of a tree. The Bender target and package dependencies also have to be considered. Simply listing the bender.yml file as a dependency is not good enough. Instead, I’m using the Bender script output as a dependency:
- The build system runs the bender script command.
- The output of that command is stored in a temporary file.
- That file is compared with the Bender script output file used by the previous build of the same target.
- If it’s different, the file is copied over, making it the Bender script output file to be used by the next build step. The Bender script output file is a dependency for synthesis, so synthesis will be triggered.
- If the temporary file is the same as the Bender script output file used by the previous build of that target, the temporary file is discarded. Synthesis will not be triggered.
This mechanism is implemented in the scripts/bender_gen_vivado_sources.sh and scripts/bender_gen_verilator_sources.sh scripts. The same scripts also generate a DepFile: a dependency list of all the sources referenced in the Bender manifest. This DepFile is referenced by the synthesis target so synthesis (or verilation) will be triggered if any of the sources change.
CMake and Bender Interaction.
I ran into a minor Bender issue while testing this: When running the bender script command on the same bender.yml file twice, it would produce slightly different output, just a reordering of some lines, but enough to trip up the compare step. The Bender maintainer was very responsive and already fixed the issue. It’s important to install Bender version 0.25.1 (or later) to get the fix.
Boxlambda_setup.sh
make setup
has been replaced with the boxlambda_setup.sh script in the repository root directory. The script initializes the git submodules used and creates the default build trees (build/sim/, build/arty-a7-35/, and build/arty-a7-100/).Make setup also used to build the Picolibc library for BoxLambda. As said in the previous section, that is no longer needed. The compiled library is checked into the source tree.
Try It Out
Below are the steps needed to set up the BoxLambda repository and build the ddr_test project on Verilator and Arty A7. The build steps for test projects hello_world, hello_dbg and picolibc_test are analogous.
Repository setup
- Install the Prerequisites.
- Get the BoxLambda repository:
git clone https://github.com/epsilon537/boxlambda/ cd boxlambda
- Switch to the boxlambda_cmake tag:
git checkout boxlambda_cmake
- Set up the repository. This initializes the git submodules used and creates the default build trees:
./boxlambda_setup.sh
Build and Run the DDR Test Image on Verilator
- Build the ddr_test project:
cd build/sim/gw/projects/ddr_test make ddr_test_sim
- Execute the generated verilator model in interactive mode:
./Vmodel -i
- You should see something like this:
DDR Test on Verilator.
Build and Run the DDR Test Image on Arty A7
- If you’re running on WSL, check BoxLambda’s documentation On WSL section.
cd build/arty-a7-[35|100]/gw/projects/ddr_test make ddr_test_impl
- Connect a terminal program such as Putty or Teraterm to Arty’s USB serial port. Settings: 115200 8N1.
- Load the bitstream onto the target board:
make ddr_test_load
- Verify the test program’s output in the terminal. You should see something like this:
DDR Test on Arty A7.
Interesting Links
https://github.com/BrunoLevy/learn-fpga#from-blinky-to-risc-v: This is a great two-part tutorial from Bruno Levy about implementing your own RISC-V processor.
Exit MIG, Enter LiteDRAM.
12/29/2022 at 09:50 • 0 commentsLiteDRAM in the BoxLambda Architecture.
Initially, the plan was to use Xilinx’s MIG (Memory Interface Generator) to generate a DDR Memory Controller for Boxlambda. At the time, that was (and maybe still is) the consensus online when I was looking for memory controller options for the Arty A7. Meanwhile, Reddit user yanangao suggested I take a look at project LiteX for a memory controller. I took the advice and started playing around a bit with Litex. One thing led to another and, long story short, BoxLambda now has a DDR memory controller based on LiteDRAM, a core of the LiteX project. If you’re interested in the longer story, read on.
Recap
This is a summary of the current state of BoxLambda. We have:
- An Ibex RISCV core, a Wishbone shared bus, a Debug Core, internal memory, a timer, two GPIO ports, and a UART core.
- A Picolibc-based standard C environment for software running on the Ibex RISCV core.
- OpenOCD-based Debug Access, both on FPGA and on Verilator.
- A Linux Makefile and Bender-based RTL build system.
LiteX and LiteDRAM
LiteX is an Open Source SoC Builder framework for FPGAs. You specify which CPU, memory, interconnect, and peripherals you want. The framework then generates the SoC and the software to go along with it. Here’s an example (with semi-randomly picked settings):
python3 digilent_arty.py --bus-standard wishbone --bus-data-width 32 --bus-interconnect crossbar --cpu-type rocket --integrated-sram-size 32768 --with-ethernet --with-sdcard --sys-clk-freq 50000000 --build --load INFO:S7PLL:Creating S7PLL, speedgrade -1. INFO:S7PLL:Registering Single Ended ClkIn of 100.00MHz. INFO:S7PLL:Creating ClkOut0 sys of 50.00MHz (+-10000.00ppm). INFO:S7PLL:Creating ClkOut1 eth of 25.00MHz (+-10000.00ppm). INFO:S7PLL:Creating ClkOut2 sys4x of 200.00MHz (+-10000.00ppm). INFO:S7PLL:Creating ClkOut3 sys4x_dqs of 200.00MHz (+-10000.00ppm). INFO:S7PLL:Creating ClkOut4 idelay of 200.00MHz (+-10000.00ppm). INFO:SoC: __ _ __ _ __ INFO:SoC: / / (_) /____ | |/_/ INFO:SoC: / /__/ / __/ -_)> < INFO:SoC: /____/_/\__/\__/_/|_| INFO:SoC: Build your hardware, easily! INFO:SoC:-------------------------------------------------------------------------------- INFO:SoC:Creating SoC... (2022-12-19 16:28:38) INFO:SoC:-------------------------------------------------------------------------------- ...
… and off it goes. That single command generates, synthesizes and loads the SoC onto your Arty A7.
LiteX is written in Migen, a Python-based tool that automates further the VLSI design process, to quote the website. At the heart of Migen sits FHDL, the Fragmented Hardware Description Language. FHDL is essentially a Python-based data structure consisting of basic constructs to describe signals, registers, FSMs, combinatorial logic, sequential logic etc. Here’s an example:
aborted = Signal() offset = base_address >> log2_int(port.data_width//8) self.submodules.fsm = fsm = FSM(reset_state="CMD") self.comb += [ port.cmd.addr.eq(wishbone.adr - offset), port.cmd.we.eq(wishbone.we), port.cmd.last.eq(~wishbone.we), # Always wait for reads. port.flush.eq(~wishbone.cyc) # Flush writes when transaction ends. ] fsm.act("CMD", port.cmd.valid.eq(wishbone.cyc & wishbone.stb), If(port.cmd.valid & port.cmd.ready & wishbone.we, NextState("WRITE")), If(port.cmd.valid & port.cmd.ready & ~wishbone.we, NextState("READ")), NextValue(aborted, 0), ) self.comb += [ port.wdata.valid.eq(wishbone.stb & wishbone.we), If(ratio <= 1, If(~fsm.ongoing("WRITE"), port.wdata.valid.eq(0))), port.wdata.data.eq(wishbone.dat_w), port.wdata.we.eq(wishbone.sel), ]
You can more or less see the Verilog equivalent. However, the fact that this is a Python data structure means that you have Python at your disposal as a meta-language to combine and organize these bits of HDL. This is a huge increase in abstraction and expressiveness, and it explains how LiteX can do what it does. The flexibility that LiteX provides in mixing and matching cores, core features, and interconnects, just can’t be achieved with vanilla SystemVerilog.
LiteX is not an all-or-nothing proposition. LiteX cores, such as the LiteDRAM memory controller, can be integrated into traditional design flows. That’s what I’ll be doing.
Why choose LiteDRAM over Xilinx MIG?
- LiteDRAM is open-source, scoring good karma points. All the benefits of open-source apply: Full access to all code, access to the maintainers, many eyeballs, the option to make changes as you please, submit bug fixes, etc.
- The LiteDRAM simulation model, the entire DDR test SoC, runs nicely in Verilator. That’s a must-have for me.
- The LiteDRAM core, configured for BoxLambda, is 50% smaller than the equivalent MIG core: 3016 LUTs and 2530 registers vs. 5673 LUTs and 5060 registers.
Generating a LiteDRAM core
LiteDRAM is a highly configurable core (because of Migen). For an overview of the core’s features, take a look at the LiteDRAM repository’s README file:
https://github.com/enjoy-digital/litedram/blob/master/README.md
You specify the configuration details in a .yml file. A Python script parses that .yml file and generates the core’s Verilog as well as a CSR register access layer for software.
Details are a bit sparse, but luckily example configurations are provided:
https://github.com/enjoy-digital/litedram/tree/master/examples
Starting from the arty.yml example, I created the following LiteDRAM configuration file for BoxLambda:
#This is a LiteDRAM configuration file for the Arty A7. { # General ------------------------------------------------------------------ "speedgrade": -1, # FPGA speedgrade "cpu": "None", # CPU type (ex vexriscv, serv, None) - We only want to generate the LiteDRAM memory controller, no CPU. "memtype": "DDR3", # DRAM type "uart": "rs232", # Type of UART interface (rs232, fifo) - not relevant in this configuration. # PHY ---------------------------------------------------------------------- "cmd_latency": 0, # Command additional latency "sdram_module": "MT41K128M16", # SDRAM modules of the board or SO-DIMM "sdram_module_nb": 2, # Number of byte groups "sdram_rank_nb": 1, # Number of ranks "sdram_phy": "A7DDRPHY", # Type of FPGA PHY # Electrical --------------------------------------------------------------- "rtt_nom": "60ohm", # Nominal termination "rtt_wr": "60ohm", # Write termination "ron": "34ohm", # Output driver impedance # Frequency ---------------------------------------------------------------- # The generated LiteDRAM module contains clock generation primitives, for its own purposes, but also for the rest # of the system. The system clock is output by the LiteDRAM module and is supposed to be used as the main input clock # for the rest of the system. I set the system clock to 50MHz because I couldn't get timing closure at 100MHz. "input_clk_freq": 100e6, # Input clock frequency "sys_clk_freq": 50e6, # System clock frequency (DDR_clk = 4 x sys_clk) "iodelay_clk_freq": 200e6, # IODELAYs reference clock frequency # Core --------------------------------------------------------------------- "cmd_buffer_depth": 16, # Depth of the command buffer # User Ports --------------------------------------------------------------- # We generate two wishbone ports, because BoxLambda has two system buses. # Note that these are _classic_ wishbone ports, while BoxLamdba uses a _pipelined_ wisbone bus. # A pipelined-to-classic wishbone adapter is needed to interface correctly to the bus. # At some point it would be nice to have an actual pipelined wishbone frontend, with actual pipelining capability. "user_ports": { "wishbone_0" : { "type": "wishbone", "data_width": 32, #Set data width to 32. If not specificied it defaults to 128 bits. "block_until_ready": True, }, "wishbone_1" : { "type": "wishbone", "data_width": 32, #Set data width to 32. If not specificied it defaults to 128 bits. "block_until_ready": True, }, }, }
Some points about the above:
- The PHY layer, Electrical and Core sections I left exactly as-is in the given Arty example.
- In the General section, I set cpu to None. BoxLambda already has a CPU. We don’t need LiteX to generate one.
- In the Frequency section, I set sys_clk_freq to 50MHz. 50MHz has been the system clock frequency in the previous BoxLambda test builds as well. Also, I haven’t been able to close timing at 100MHz.
- In the User Ports section, I specified two 32-bit Wishbone ports. In the BoxLambda Architecture Diagram, you’ll see that BoxLambda has two system buses. The memory controller is hooked up to both.
I generate two LiteDRAM core variants from this configuration:
- For simulation:
litedram_gen artya7dram.yml --sim --gateware-dir sim/rtl --software-dir sim/sw --name litedram
- For FPGA:
litedram_gen artya7dram.yml --gateware-dir arty/rtl --software-dir arty/sw --name litedram
The generated core has the following interface:
module litedram ( `ifndef SYNTHESIS input wire sim_trace, /*Simulation only.*/ `endif input wire clk, `ifdef SYNTHESIS input wire rst, /*FPGA only...*/ output wire pll_locked, output wire [13:0] ddram_a, output wire [2:0] ddram_ba, output wire ddram_ras_n, output wire ddram_cas_n, output wire ddram_we_n, output wire ddram_cs_n, output wire [1:0] ddram_dm, inout wire [15:0] ddram_dq, inout wire [1:0] ddram_dqs_p, inout wire [1:0] ddram_dqs_n, output wire ddram_clk_p, output wire ddram_clk_n, output wire ddram_cke, output wire ddram_odt, output wire ddram_reset_n, `endif output wire init_done, /*FPGA/Simulation common ports...*/ output wire init_error, input wire [29:0] wb_ctrl_adr, input wire [31:0] wb_ctrl_dat_w, output wire [31:0] wb_ctrl_dat_r, input wire [3:0] wb_ctrl_sel, input wire wb_ctrl_cyc, input wire wb_ctrl_stb, output wire wb_ctrl_ack, input wire wb_ctrl_we, input wire [2:0] wb_ctrl_cti, input wire [1:0] wb_ctrl_bte, output wire wb_ctrl_err, output wire user_clk, output wire user_rst, input wire [25:0] user_port_wishbone_0_adr, input wire [31:0] user_port_wishbone_0_dat_w, output wire [31:0] user_port_wishbone_0_dat_r, input wire [3:0] user_port_wishbone_0_sel, input wire user_port_wishbone_0_cyc, input wire user_port_wishbone_0_stb, output wire user_port_wishbone_0_ack, input wire user_port_wishbone_0_we, output wire user_port_wishbone_0_err, input wire [25:0] user_port_wishbone_1_adr, input wire [31:0] user_port_wishbone_1_dat_w, output wire [31:0] user_port_wishbone_1_dat_r, input wire [3:0] user_port_wishbone_1_sel, input wire user_port_wishbone_1_cyc, input wire user_port_wishbone_1_stb, output wire user_port_wishbone_1_ack, input wire user_port_wishbone_1_we, output wire user_port_wishbone_1_err );
Some points worth noting about this interface:
- A Wishbone control port is generated along with the two requested user ports. LiteDRAM CSR register access is done through this control port.
- All three Wishbone ports are classic Wishbone ports, not pipelined. There is no stall signal.
- The Wishbone port addresses are word addresses, not byte addresses.
- The LiteDRAM module takes an external input clock (clk) and generates a 50MHz system clock (user_clk). The module contains a clock generator.
- On FPGA, the LiteDRAM module takes an asynchronous reset (rst) and provides a synchronized reset (user_rst). The module contains a reset synchronizer.
Integrating the LiteDRAM core
Litedram_wrapper
I created a litedram_wrapper module around litedram.v:
This wrapper contains:
- byte-to-word address adaptation on all three Wishbone ports.
- Pipelined-to-Classic Wishbone adaptation. The adapter logic comes straight out of the Wishbone B4 spec section 5.2, Pipelined master connected to standard slave. The stall signal is used to avoid pipelining:
/*Straight out of the Wishbone B4 spec. This is how you interface a classic slave to a pipelined master. *The stall signal ensures that the STB signal remains asserted until an ACK is received from the slave.*/ assign user_port_wishbone_p_0_stall = !user_port_wishbone_p_0_cyc ? 1'b0 : !user_port_wishbone_c_0_ack;
How long to STB?
One Rookie mistake I made early on was to just set the Wishbone stall signal to 0. I figured that, as long as I didn’t generate multiple outstanding transactions, that should work just fine. That’s not the case, however. Wishbone transactions to the LiteDRAM core would just block. The reason is that in classic Wishbone, STB has to remain asserted until an ACK or ERR is signaled by the slave. Pipelined Wishbone doesn’t work that way. In pipelined Wishbone, as long as the slave is not stalling, a single access STB only remains asserted for one clock cycle.
Classic Wishbone transaction (Illustration taken from Wishbone B4 spec).
Pipelined Wishbone transaction - single access (Illustration taken from Wishbone B4 spec).
Hence the pipelined-to-classic Wishbone adapter in litedram_wrapper.
More Wishbone Issues: Core2WB and WB_Interconnect_SharedBus
With the litedram_wrapper in place, Wishbone transactions still weren’t working properly. Waveform analysis shows that, from the point of view of litedram_wrapper, the Wishbone Bus Master wasn’t well-behaved. That problem could either come from the Ibex memory-interface-to-wishbone adapter, core2wb.sv, or the Wishbone shared bus implementation used by the test build, wb_interconnect_shared_bus.sv, or both.
This is the Ibex Memory Interface specification:
https://ibex-core.readthedocs.io/en/latest/03_reference/load_store_unit.html#load-store-unit
There are two such interfaces. One for data, one for instructions.
The job of core2wb is to adapt that interface to a pipelined Wishbone bus master interface. That Wishbone bus master in turn requests access to the shared bus. It’s up to wb_interconnect_shared_bus to grant the bus to one of the requesting bus masters and direct the transaction to the selected slave. If either one of those modules has a bug, that will result in an incorrectly behaving bus master, from the point of view of the bus slave.
From Ibex to LiteDRAM.
core2wb.sv and wb_interconnect_shared_bus.sv are part of the ibex_wb repository. The ibex_wb repository no longer appears to be actively maintained. I looked long and hard at the implementation of the two modules and ultimately decided that I couldn’t figure out the author’s reasoning. I decided to re-implement both modules:
- Core2wb has two states: Idle and Transaction Ongoing. In the Idle state, when Ibex signals a transaction request (core.req), the Ibex memory interface signals get registered, a single access pipelined Wishbone transaction is generated and core2wb goes to Transaction Ongoing state. When a WB ACK or ERR response is received, core2wb goes back to idle. While Transaction Ongoing state, the memory interface grant (gnt) signal is held low, so further transaction requests are stalled until core2wb is idle again Multiple outstanding transactions are currently not supported. I hope to add that capability someday.
Core2WB State Diagram.
- WB_interconnect_shared_bus also has two states: In the Idle state, a priority arbiter monitors the CYC signal of participating Bus Masters. When one or more Bus Masters assert CYC, the arbiter grants access to the lowest order Bus Master and goes to Transaction Ongoing state. When that Bus Master de-asserts CYC again, we go back to Idle state. Slave selection and forwarding of WB signals is done with combinatorial logic.
WB_Interconnect_Shared_Bus State Diagram.
With those changes in place, Ibex instruction and data transactions to LiteDRAM are working fine.
ddr_test_soc
/projects/ddr_test/rtl/ddr_test_soc.sv has the test build’s top-level. It’s based on the previous test build’s top-level, extended with the LiteDRAM wrapper instance.
litedram_wrapper litedram_wrapper_inst ( .clk(ext_clk100), /*100MHz External clock is input for LiteDRAM module.*/ .rst(~ext_rst_n), /*External reset goes into a reset synchronizer inside the litedram module. The output of that synchronizer is sys_rst.*/ .sys_clk(sys_clk), /*LiteDRAM outputs 50MHz system clock...*/ .sys_rst(sys_rst), /*...and system reset.*/ .pll_locked(pll_locked), `ifdef SYNTHESIS .ddram_a(ddram_a), .ddram_ba(ddram_ba), .ddram_ras_n(ddram_ras_n), .ddram_cas_n(ddram_cas_n), .ddram_we_n(ddram_we_n), .ddram_cs_n(ddram_cs_n), .ddram_dm(ddram_dm), .ddram_dq(ddram_dq), .ddram_dqs_p(ddram_dqs_p), .ddram_dqs_n(ddram_dqs_n), .ddram_clk_p(ddram_clk_p), .ddram_clk_n(ddram_clk_n), .ddram_cke(ddram_cke), .ddram_odt(ddram_odt), .ddram_reset_n(ddram_reset_n), `endif .init_done(init_done_led), .init_error(init_err_led), .wb_ctrl_adr(wbs[DDR_CTRL_S].adr), .wb_ctrl_dat_w(wbs[DDR_CTRL_S].dat_m), .wb_ctrl_dat_r(wbs[DDR_CTRL_S].dat_s), .wb_ctrl_sel(wbs[DDR_CTRL_S].sel), .wb_ctrl_stall(wbs[DDR_CTRL_S].stall), .wb_ctrl_cyc(wbs[DDR_CTRL_S].cyc), .wb_ctrl_stb(wbs[DDR_CTRL_S].stb), .wb_ctrl_ack(wbs[DDR_CTRL_S].ack), .wb_ctrl_we(wbs[DDR_CTRL_S].we), .wb_ctrl_err(wbs[DDR_CTRL_S].err), /*Eventually we're going to have two system buses, but for the time being, to allow testing, *we hook up both user ports to our one shared bus. *Both ports address the same 256MB of DDR memory, one at base address 'h40000000, the other at 'h50000000.*/ .user_port_wishbone_p_0_adr(wbs[DDR_USR0_S].adr), .user_port_wishbone_p_0_dat_w(wbs[DDR_USR0_S].dat_m), .user_port_wishbone_p_0_dat_r(wbs[DDR_USR0_S].dat_s), .user_port_wishbone_p_0_sel(wbs[DDR_USR0_S].sel), .user_port_wishbone_p_0_stall(wbs[DDR_USR0_S].stall), .user_port_wishbone_p_0_cyc(wbs[DDR_USR0_S].cyc), .user_port_wishbone_p_0_stb(wbs[DDR_USR0_S].stb), .user_port_wishbone_p_0_ack(wbs[DDR_USR0_S].ack), .user_port_wishbone_p_0_we(wbs[DDR_USR0_S].we), .user_port_wishbone_p_0_err(wbs[DDR_USR0_S].err), .user_port_wishbone_p_1_adr(wbs[DDR_USR1_S].adr), .user_port_wishbone_p_1_dat_w(wbs[DDR_USR1_S].dat_m), .user_port_wishbone_p_1_dat_r(wbs[DDR_USR1_S].dat_s), .user_port_wishbone_p_1_sel(wbs[DDR_USR1_S].sel), .user_port_wishbone_p_1_stall(wbs[DDR_USR1_S].stall), .user_port_wishbone_p_1_cyc(wbs[DDR_USR1_S].cyc), .user_port_wishbone_p_1_stb(wbs[DDR_USR1_S].stb), .user_port_wishbone_p_1_ack(wbs[DDR_USR1_S].ack), .user_port_wishbone_p_1_we(wbs[DDR_USR1_S].we), .user_port_wishbone_p_1_err(wbs[DDR_USR1_S].err) );
Clock and Reset generation is now done by LiteDRAM. LiteDRAM accepts the external clock and reset signal and provides the system clock and synchronized system reset. Previous BoxLambda test builds had a separate Clock-and-Reset-Generator instance for that.
In this test build, both user ports are hooked up to the same shared bus. That doesn’t make a lot of sense of course. I’m just doing this to verify connectivity over both buses. Eventually, BoxLambda is going to have two buses and LiteDRAM will be hooked up to both.
LiteDRAM Initialization
When the litedram_gen.py script generates the LiteDRAM Verilog core (based on the given .yml configuration file), it also generates the core’s CSR register accessors for software:
- For FPGA: https://github.com/epsilon537/boxlambda/tree/develop/components/litedram/arty/sw/include/generated
- For simulation: https://github.com/epsilon537/boxlambda/tree/develop/components/litedram/sim/sw/include/generated
The most relevant files are csr.h and sdram_phy.h. They contain the register definitions and constants used by the memory initialization code. Unfortunately, these accessors are not the same for the FPGA and the simulated LiteDRAM cores. We’re going to have to use separate software builds for FPGA and simulation.
Sdram_init()
Sdram_phy.h also contains a function called init_sequence(). This function gets invoked as part of a more elaborate initialization function called sdram_init(). Sdram_init() is not part of the generated code, however. It’s part of sdram.c, which is part of liblitedram, which is part of the base Litex repository, not the LiteDRAM repository:
https://github.com/epsilon537/litex/tree/master/litex/soc/software/liblitedram
sdram_init() vs. init_sequence().
It’s not clear to me why the liblitedram is not part of the LiteDRAM repository, but’s not a big deal. I integrated the sdram_init() function from liblitedram in the BoxLambda code base and it’s working fine.
To get things to build, I added Litex as a git submodule, to get access to liblitedram. I also tweaked some CPPFLAGS and include paths. The resulting Makefiles are checked-in here:
- FPGA: https://github.com/epsilon537/boxlambda/blob/master/sw/projects/ddr_test/fpga/Makefile
- Sim: https://github.com/epsilon537/boxlambda/blob/master/sw/projects/ddr_test/sim/Makefile
It’s worth noting that liblitedram expects a standard C environment, which I added in the previous BoxLambda update.
DDR Test
The DDR test program is located here:
https://github.com/epsilon537/boxlambda/blob/master/sw/projects/ddr_test/ddr_test.c
The program boots from internal memory. It invokes sdram_init(), then performs a memory test over user port 0, followed by user port 1. Finally, the program verifies CPU instruction execution from DDR by relocating a test function from internal memory to DDR and branching to it.
The memory test function used is a slightly modified version of the memtest() function provided by Litex in liblitedram.
Relevant Files
- https://github.com/enjoy-digital/litex/blob/master/litex/soc/software/liblitedram/sdram.c
- https://github.com/epsilon537/boxlambda/blob/master/components/litedram/common/rtl/litedram_wrapper.sv
- https://github.com/epsilon537/boxlambda/blob/master/components/litedram/arty/rtl/litedram.v
- https://github.com/epsilon537/boxlambda/blob/master/components/litedram/sim/rtl/litedram.v
- https://github.com/epsilon537/boxlambda/blob/master/components/litedram/artya7dram.yml
- https://github.com/epsilon537/boxlambda/blob/master/projects/ddr_test/rtl/ddr_test_soc.sv
- https://github.com/epsilon537/boxlambda/blob/master/sw/projects/ddr_test/ddr_test.c
- https://github.com/epsilon537/boxlambda/blob/master/sw/projects/ddr_test/fpga/Makefile
- https://github.com/epsilon537/boxlambda/blob/master/sw/projects/ddr_test/sim/Makefile
- https://github.com/epsilon537/boxlambda/blob/master/components/litedram/arty/sw/include/generated/csr.h
- https://github.com/epsilon537/boxlambda/blob/master/components/litedram/arty/sw/include/generated/sdram_phy.h
- https://github.com/epsilon537/boxlambda/blob/master/components/litedram/sim/sw/include/generated/csr.h
- https://github.com/epsilon537/boxlambda/blob/master/components/litedram/sim/sw/include/generated/sdram_phy.h
Try It Out
Repository setup
- Switch to the enter_litedram tag:
git checkout enter_litedram
- Set up the repository. This initializes the git submodules used and builds picolibc for BoxLambda:
make setup
- Build the test project:
cd projects/ddr_test make sim
cd generated ./Vmodel -i
cd projects/ddr_test make impl
- Run the project:
make run
DDR Test on Arty A7-35T.
Other Changes
To minimize the differences with the Arty A7-35T (Little BoxLambda), I decided to use the Arty A7-100T rather than the Nexys A7 as the Big BoxLambda variant.
I noticed belatedly that I didn’t create a constraint for the tck JTAG clock, so no timing analysis could be done on the JTAG logic. I added the following to the .xdc constraints file. Vivado’s timing analysis is much happier now.
#This is the JTAG TCK clock generated by the BSCANE2 primitive. #Note that the JTAG top-level ports (incl. TCK) are not used in a synthesized design. They are driven by BSCANE2 instead. create_clock -period 1000.000 -name dmi_jtag_inst/i_dmi_jtag_tap/tck_o -waveform {0.000 500.000} [get_pins dmi_jtag_inst/i_dmi_jtag_tap/i_tap_dtmcs/TCK]
- I have merged the development branch to the master branch. Going forward, I intend to do that every time I put down a release label for a new Blog post.
Interesting Links
https://github.com/antonblanchard/microwatt: An Open-Source FPGA SoC by Anton Blanchard using LiteDRAM. I found it helpful to look at that code base to figure out how to integrate LiteDRAM into BoxLambda.
