8mm Film Scanner V2
Easier to build, more powerful scanning and post scan processing of films.
This project is based on the original 8mm Film Scanner https://hackaday.io/project/167426-8mm-film-scanner. I branched it out due to incompatibility of the new components to the old design. V2 will have several improvements over the original film scanner. The aim is to make it easier to print and build, increase the performance by using a Raspberry Pi 4 and the optional use of a HQ camera module. All changes are in an early phase and need to still be tested. I'll post the files for the parts here once they work.
The new mount plate comes with various improvements. The rolls are now mounted with 3mm screws instead of the previous 3d printed parts and no nuts are used. They also have now handles so its easier to lift them up when loading a film.
The roll that detects the status of the winded up part of the film can now be moved in a larger angle and also has a handle.
The rolls themselves have a clear position for the bearings. The film clearer is more robust than the previous version. I printed the plate itself in PETG, the movable parts in PLA. All with a 0.4mm nozzle, so it should be easy for everyone to print.
roll mount V1
roll mount NEW V2
mount plate back
Schematic_film copier mk2_2022-04-25.pdf
New Schematic
Adobe Portable Document Format - 68.83 kB - 04/25/2022 at 04:13
Preview
  • the film scanner HAT is assembled
    Anton05/11/2022 at 04:26 0 comments
    finally all components arrived and I could assemble the HAT.
    I also decided to go with an SSD drive for optimum performance.
    the Pi4 sits on the SSD board
    the HAT is assembled and ready
  • stl files for new core unit
    Anton05/03/2022 at 08:20 0 comments
    if you want to test the new core unit, I've put the stl files on my gdrive:
    https://drive.google.com/drive/folders/1kwc13bQUv-6axDW3g2RIkeYDfymdQTxG?usp=sharing
    Important note:
    The mount plate V2 is not compatible with the version 1 of the scanner. I've added a compatible version.
    I've used PETG for the mount plate and PLA for the rest - all printed with a 0.4mm nozzle.
  • first go on the case for the 5 inch display
    Anton04/25/2022 at 04:22 0 comments
    the front case needed complete redesign to make space for a larger 5 inch HDMI display.
    the buttons are now below the display. The cover is printed in one piece, including the buttons. Only a color change was done after the first three layers.
  • new PCB design
    Anton04/25/2022 at 04:10 0 comments
    In order to provide cooling to the Raspberry Pi 4, the new design has space for a cpu cooling fan. The GPIO assignment is new - so it is not compatible with the software of the original scanner.
    It also includes now a switch to toggle between S8 and R8.
View all 4 project logs
wedlake wrote 08/27/2025 at 18:38 point
Very interested in the V2, Will the PCB files be available ?
ncysys wrote 03/07/2024 at 16:02 point
Hi Guys, I just found this interesting lens for the Raspberry Pi HQ camera with the c/cs mount.  It is a macro / micro lens that doesn't need any add-on lenses. You can purchase it here:  https://shop.pimoroni.com/products/microscope-stand-with-0-12-1-8x-lens?variant=31885089046611   Here is a photo and a sample of a movie film image.
giancarlo wrote 01/31/2024 at 14:27 point
Hi,
any news about the possibility to integrate the Raspberry Pi Camera Module 3?
dirk wrote 04/23/2023 at 19:19 point
Hi, this is a very nice project. I have a collection R8 and S8 films from my father and grandfather which wait to be digitized. I already ordered several parts like gears, magnets etc. Not all is clear, like which parts from v1 are to be printed. Is it possible to share a recent STEP file? That way I can inspect in 3d how things fit together.
ChristianWaechter wrote 04/20/2023 at 19:57 point
Hello, I really like your project and wait for you to proide more information about this V2 build! Keep up the great work! By the way, this would be a great project that can be combined with this DIY wetgate for cleaning: https://www.super-8.com/film-reiniger.html
giancarlo wrote 03/28/2023 at 12:22 point
Hi, I have already printed the V1 Version of the scanner but not yet assembled. Can I recover some parts of the 3D print of do I have to reprint all?
christer.vollmer wrote 03/20/2023 at 21:57 point
Can I use a Raspberry Pi Camera Module 3 Camera 12 Million Pixel Camera for this project?
Is there a macro lens that fits the bill for this camera module?
giancarlo wrote 03/28/2023 at 10:51 point
Yes, it would be nice to use the new V3 Camera.  It has also an HDR functionality that could be very helpful
giancarlo wrote 06/26/2024 at 06:53 point
Hi Christer, I found this camera
https://www.arducam.com/64mp-ultra-high-res-camera-raspberry-pi/
64Mpixel and should be the same mount
christer.vollmer wrote 03/20/2023 at 21:49 point
Since it's very hard to find a Raspberry Pi 4, model B nowadays, what's a good alternative?
Will the Banana Pi or the Orange Pi versions do the job?
What are the specs that must be fulfilled?
Lars Lund Hansen wrote 02/27/2023 at 18:41 point
 Hi Anton,
I discovered your
brilliant and very inspiring 8mm Film Scanner Projects for about 3 months ago. Now I have a working film scanner that has been able to
scan my 60 years old 8mm Regular films.
I had some problems along the way, but mostly with the software, and that lead me to starting my own software project:
“Program with a GUI for the Anton 8mm Film Scanner”.
https://hackaday.io/project/189773-program-with-a-gui-for-the-anton-8mm-film-scanner
I will continue to follow your V2 project, and look forward to see what comes next.
Best Regards
Lars
Roger Mason wrote 12/04/2022 at 17:55 point
Anton, care to estimate when your V2 8mm Film Scanner project will be published & ready for replication?  I am considering whether to replicate your V1 version using the retrofit V2 mount plate or wait for your full V2 version.  Thx
robteed wrote 10/26/2022 at 03:23 point
Hello Anton, Have you considered making a gate and other components for 16mm film? I have an extensive collection of 16mm films that I would like to digitize, I have been collecting parts for quite some time and I think I have everything I need, I have an ArduCam 16meg camera with autofocus that is able to focus well on a 16mm frame of film. I have stepper motors and Arduinos/Raspberry Pi's.  I have an FLA printer and two resin printers. I do not know how to use 3D design software good enough to create something like your project. I am trying to learn Blender 3D.
Louis Hillebrand wrote 10/23/2022 at 16:30 point
Anton, have you published the updated cad for the Stepper HAT? The same question for the 5 inch screen mount?
Gianluca wrote 10/18/2022 at 16:17 point
Nice Project - it comes handy: can you publish the updated BOM? I guess that apart from the display, the rest should be similar.
Roger Mason wrote 10/16/2022 at 17:09 point
Anton, have you published an updated film scanner cad asm drwg that includes the newer V2 components (V2 backplate and mount for 5in display)?  The only published  asm drwg I have seen is of the V1 film scanner.   Thx
Mauricio Tecles wrote 06/11/2022 at 22:28 point
Hi Anton! As I wrote you on the original film scanner webpage I will try to use Arduino, my computer and the core of your fine project. I downloaded the .step file of your V1 scanner and I took a look at it with Fusion 360.
 It seams that an 8mm film thickness is 0.15mm, a cement splice 0.3mm. What about enlarging the gap between the film plate and the the camera rail to, say, at least 0.45mm? That would give some extra space for the splice, and I am thinking of something to gently press down the film. I am making some modifications on the film plate and I will share it so you can take a look at it, if you will.
Mauricio Tecles wrote 06/15/2022 at 00:01 point
Hi again! I have maide some modiffications as suggestions:
1- The gap between the film plate and the camera lens rail enlarged to 0.45mm.
2- Two "craisy" ways to press the film down on the film plate: one uses a 3mm LED, as it has a polished rounded lens; the other uses a ski/sled. Both with a 3x8x4 ballbearing as weight.
I have used the version 1 .step file just as reference.
I have not 3D printed then, they are just suggestions to be considered or not.
The Fusion 360 files are shared on my Google Drive:
https://drive.google.com/drive/folders/1fpVlumdcgDRgKHHitJZPe8E0gs6YF_v_?usp=sharing
DeadParadise wrote 05/14/2022 at 01:16 point
I just wanted to say that you are doing an amazing job and I'm excited for the new version! I just started getting back into shooting super 8 and I have been looking for scanning solutions. I've also been wanting to work more with electronics using my raspberry pi, so I feel like this would be the perfect next project for me. If you have a donation link, please do share it.
