Hackaday.io Hackaday.io
Sign up Log in
Robot buddy
A cute robot head assistant with movement and expressions displayed through an LED matrix.
tanguyTanguy
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.7k views
2 comments
24 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 14
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
2.7k
2
24
27
Team (1)
  • tanguyTanguy
Join this project's team
  • Instagram
  • GitHub
MISC
ongoing project
head ROBOT LEDS servo Motors Robotics chatbot virtual assistant ai electronics
Related lists
mini robot
smal thing
This project was created on 04/25/2022 and last updated 5 months ago.
Description
It’s a cute robot head with movement and expressions displayed through an LED matrix. I plan to integrate it with platforms like Google Home and ChatGPT to create interactions similar to a virtual assistant. You can purchase the round matrix PCB i designed for this on my Tindie page. (Looking for a name for him; if you have suggestions, I’d love to hear them!)
Project Logs
Collapse
  • Sponsoring PCBWAY
    Tanguy • 10/14/2025 at 16:03 • 0 comments
    This board is an ESP8266 shield. It features a PCA I2C servomotor driver, power management and protection, 3.3V to 5V signal conversion for the LED matrix, a buzzer, and I²C/serial extension ports.
    This will make the robot much cleaner by replacing multiple jumper-connected boards.
    Thanks to PCBWay for sponsoring my project — if you need high-quality PCBs delivered fast, go check out their offers!
  • All in one PCB for robot head
    Tanguy • 10/14/2025 at 15:54 • 0 comments
    I am working on an ESP shield PCB for the head.
  • Finished the new design
    Tanguy • 05/14/2025 at 22:21 • 0 comments
    Finished the new design — now each axis of the neck is supported by bearings!
  • New round matrix PCB
    Tanguy • 05/14/2025 at 22:13 • 0 comments
    New round matrix PCB with JST HX connectors on the back.
  • Working on a cleaner version
    Tanguy • 04/06/2023 at 08:56 • 0 comments
    I am working on a cleaner version where all the electronics fit inside the head, and a new support base holds the neck.
  • PCBWay sponsoring
    Tanguy • 06/19/2022 at 19:36 • 0 comments
    I just received a sponsorship from PCBWay ! Thanks to them for supporting my project.
    All 5 PCBs are of good quality and were produced and shipped quickly.
    If you have a PCB project, take a look at their offers : https://www.pcbway.com
  • Real glass and light diffuser
    Tanguy • 06/05/2022 at 11:26 • 0 comments
  • Head movement test n°2
    Tanguy • 04/25/2022 at 16:50 • 0 comments
  • Head movement test n°1
    Tanguy • 04/25/2022 at 16:50 • 1 comment
  • Neck mechanism test n°5
    Tanguy • 04/25/2022 at 16:38 • 0 comments
View all 14 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Quoc Tuan wrote 04/27/2022 at 03:12 • point
i like it. Can you help me redo it?
Tanguy wrote 05/18/2022 at 19:23 • point
I am working on a PCB for the leds, it will make it more easy than soldering pieces of leds strip together. Still working on the 3d files to, it's not really friendly to assemble for the moment,  I am  improving it.
The 2018 Hackaday Prize
A 6cm 4-legged Ball Robot
Project Owner Contributor
4B Robot
carl-bugejaCarl Bugeja
A robot fish with pcb fins
Robot Fish (PCB Fins)
A small quadruped robot made of PCB, with 8 servo motors.
FoxMini
tanguyTanguy
Do you want to create your own robot? than this is your best guide. This is a smart robot controlled by an android app so easy to build.
4WD Smart Robot
diy-guy-chrisDIY GUY Chris
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Robot buddy", please tell us the reason.
Send message
Remove Member
