Wow! Distance resolution 0.006mm
A project log for Fast Bed leveling sensor
High resolution Distance sensor for 3D printer Bed Leveling
markmark 05/05/2022 at 03:350 Comments
I did some tests with new board those days, and the result is very good, the distance resolution is 0.006mm~0.01mm in the distance range from 0.5mm ~ 7 mm; and 0.01~0.03 mm in the range from 7mm~10mm. and now write software for the connecting i2c protocol
