when I go to the link, then on bottom click klipper it then takes you to how to patch klipper. Does the install instructions need to change, or am I misunderstanding what this means? I already have klipper, so I have to patch and reinstall?
I have tried to let the real time leveling work with klipper but not stable due to the speed limit of MCU to RPI, Maybe there are other solutions that I haven't found yet.
also I saw you referenced a chip I’ve used before tca355g, did you just figure out how to use the capacitance chip, then found one for inductance?
Why doesn't the real time leveling work with Klipper?
