Benefit:
- Avoid the temperature drift.
- Auto z_offset Calibrate
From the data bellow we can see that the temperature drift will only change the z_offset, rise or low the bed mesh, but does not change the bed mesh with this BDsensor. that means the bed mesh is the same even with different temperature.
3. Repeatability: +/-0.005mm
mark
