new hardware
19 hours ago • 0 comments -
auto adjust z axis test
Wow! Distance resolution 0.006mm
05/05/2022 at 03:35 • 0 commentsI did some tests with new board those days, and the result is very good, the distance resolution is 0.006mm~0.01mm in the distance range from 0.5mm ~ 7 mm; and 0.01~0.03 mm in the range from 7mm~10mm. and now write software for the connecting i2c protocol
the first prototype testing
04/27/2022 at 08:05 • 0 comments
