Panel Orientation App
A project log for Low cost solar panel solution (MPPT + sun tracker)
portable flexible panel + MPPT controller + solar tracker system less than 55 USD ????
jp-gleyzesJP Gleyzes 07/27/2022 at 10:020 Comments
I finally coded a small Android Application to help to position the solar panel and thus avoid calibration of the solar tracker !
Very simple to use:
and that's it !
The app needs to know your position to compute solar angle at your location. So GPS permission is required...
