A new calibration procedure
A project log for Low cost solar panel solution (MPPT + sun tracker)
portable flexible panel + MPPT controller + solar tracker system less than 55 USD ????
JP GleyzesJP Gleyzes 10/05/2022 at 09:030 Comments
Introducing the new Azimut mechanics induced a side effect... My manual calibration procedure no longer worked for this axis.
This is due to the fact that:
So I decided to implement a new procedure of calibration into the Android application. Don't panic it is even simpler than before!
Here is what you should see on the screen
And the panel will rotate to the right position, pointing to the sun !
This should be done only once after powering the ESP32.
Once done this calibration will be kept into the memory of the ESP32 (even during night).
