Publishing V2 of Solar Tracker firmware and Android companion App
A project log for Low cost solar panel solution (MPPT + sun tracker)
portable flexible panel + MPPT controller + solar tracker system less than 55 USD ????
jp-gleyzesJP Gleyzes 09/17/2022 at 17:030 Comments
As promized, here is the source code for:
Don't forget to dowload the V2 of these files.
As usual, if you prefer to download the Apk it is here!
They work together and allow to ease the Solar Tracker Initialization
Full details into this log
