First Prototype!
A project log for Moss Microbial Fuel Cell
Harvesting electricity with the help of moss dwelling microorganisms!
guru-sanGuru-san 04/28/2022 at 23:490 Comments
The first step was to build a prototype as a first PoC, to verify that the concept works (it adds up on paper, but generating electricity from microbes living in moss is incredible!). So I went to pick up moss nearby and built an experimental setup similar to this build
The build consist of a plastic container, a lining of aluminium foil at the bottom as a cathode, a layer of soil, another layer of aluminium foil as anode, and then a bit of soil and the moss. Here is what it looks like:
                                             And then build a second on for control
I monitored the voltage I could get on the 2 fuel cells over a few days, as expected it took a bit of time to settle, here are the highest voltage measured on them on each day:
Cell 1Cell 2
Day 141mV16mV
Day 279mV20mV
Day 3131mV  32mV
Day 4141mV24mV
                                                     Measurement of Cell 1's voltage on the first day
Note this is just the voltage - not the power, although in the case of microbial fuel cells they are often proportional. Further testing seems to confirm that cell 2 is underperfoming.
Next time!
The next step is to find a way to harvest the very low power electric charge and design a better container and set of anode and cathode~
