PCB Design
A project log for DIY Solar Panel Monitoring System
A solar Panel monitoring system with both local and remote display
open-green-energyOpen Green Energy 05/03/2022 at 12:040 Comments
I have drawn the schematic by using EasyEDA online software and then designed a custom PCB for this project. The PCB is designed for mounting the different modules instead of using a lot of components. I have ordered my PCB from JLCPCB and received it within 7 days.
You can download the Gerber files attached below.
