Sims
A project log for Energy Independence While Travelling
Bring your own clean power. Pack a Kite Turbine in your EV
roddy-rags-readRoddy "Rags" Read 06/03/2022 at 08:460 Comments
Got a couple of sims for you
A view of our long term ambition - a network of networks, Kite Turbine field layout
Rough animation of a Backline handling Bot to improve ease of deployment and safety
Using a Backline Bot will likely be our standard method for single turbine releases on flat enough ground till maybe 100 ~200 kW
After that  - inside the net of nets (as above) deployment from the ground station will be better...
Might look like this
For a tilting carousel like this which releases the rotors and transmission lines and rings - We'll want the rotors to be able to expand in tension once spinning.
