2022_12_29_Full_description.pdf
A detailed description and operating manual for the V2_0f integrated controller board.
Adobe Portable Document Format - 2.03 MB - 12/31/2022 at 06:52
Preview
2022_12_29_Full_description.doc
msword - 2.14 MB - 12/31/2022 at 06:49
Download
221227_Code_for_V2_0f.zip
Functional code for the V2_0f board. It yet requires some cleanup of the comments and maybe some fine tuning for better usability.
x-zip-compressed - 32.14 kB - 12/28/2022 at 19:29
Download
Pogo_Board.zip
Open Source files for the Pogo test board (MIT license). Full instructions will follow when tested.
x-zip-compressed - 3.62 MB - 10/30/2022 at 19:27
Download
v2_0f_board_for_solar_tracking_and_robotics.docx
A detailed description of the Magnetic Solar Tracker V2.0f board that also takes robotic applications into account.
document - 1.79 MB - 10/23/2022 at 06:40
Download
v2_0f_board_for_solar_tracking_and_robotics.pdf
Adobe Portable Document Format - 1.26 MB - 10/23/2022 at 06:40
Preview
Magnetic_CPV_Tracker_v2_0f_Eagle_CAD_CAM_BOM_documentation.zip
Complete data set and documentation for the Magnetic CPV Tracker v2.0f board. You can order assembled boards yourself using the CAM outputs and the BOM file. In case you wish to modify the board layout we provide the Eagle schematic and board file. This is real open source!
x-zip-compressed - 852.32 kB - 10/22/2022 at 11:49
Download
license.txt
MIT license
text/plain - 1.08 kB - 05/01/2022 at 12:41
Download
2022_04_29_Tracker_4_contest.pdf
A slightly modified version of the presentation I have given at the CPV-18 conference with annotations concerning the pictures which are also used in the conference paper and which will be published through AIP (public access).
Adobe Portable Document Format - 1.35 MB - 04/29/2022 at 16:18
Preview
2021_08_14_Full_description.pdf
Detailed description of how to build and operate the tracker controller based on a few breakout boards. More at <a target="_blank" rel="noopener noreferrer" href="https://github.com/solhunter">https://github.com/solhunter</a>
Adobe Portable Document Format - 2.61 MB - 04/28/2022 at 16:40
Preview
