File uploaded
A project log for Rave in a briefcase
Thrifted briefcase, dumpster dived rails, electronics out of an old skiff, panel lasercutted out of a broken frame
tilloTillo • 05/24/2022 at 21:25•0 Comments
I uploaded the dxf for the front panel holding the elecrronics from the nitfty case.  Missing the holes of my headphone stereo output, since I drilled it afterwards. It can maybe used to make a 1U panel as well, it almost look like 1U but its not.
Lost the standoff which hold both the rails unfortunately but those schould be done fitting your briefcase and pieces of wood anyway.
