The most suitable application for a round display is a programmable watch.
Using the GFX Library for Arduino (https://github.com/moononournation/Arduino_GFX) , we can easily configure and start using the round LCD, printing text and image on the display and playing animation.
What's best, the AMB23 dev board comes with built-in audio codec and an on-board audio jack for WAV audio data playing, so we can record a voice message and convert it to WAV, put it on the SD card then play the voice message at the designated time.
Here is the code,
   Arduino Watch Lite Version
   You may find full version at: https://github.com/moononournation/ArduinoWatch
 * Start of Arduino_GFX setting
 * Arduino_GFX try to find the settings depends on selected board in Arduino IDE
 * Or you can define the display dev kit not in the board list
 * Defalult pin list for non display dev kit:
 * ESP32 various dev board     : TFT_CS:  5, TFT_DC: 27, TFT_RST: 33, TFT_BL: 22
 * ESP8266 various dev board   : TFT_CS: 15, TFT_DC:  4, TFT_RST:  2, TFT_BL:  5
 * RTL872x various dev board   : TFT_CS: 12, TFT_DC: 14, TFT_RST: 15, TFT_BL: 13, VCC: 3V3, GND: GND, SDA: MOSI, SCL: CLK
 * Go to Arduino_GFX_Library.h and update the TFT misc pins according to the definitions listed below
 * #elif defined(RTL8722DM)
   #define TFT_CS 12
   #define TFT_DC 14
   #define TFT_RST 15
   #define TFT_BL 13
 * Arduino Nano, Micro and more: TFT_CS:  9, TFT_DC:  8, TFT_RST:  7, TFT_BL:  6
#include <Arduino_GFX_Library.h>
/* More dev device declaration: https://github.com/moononournation/Arduino_GFX/wiki/Dev-Device-Declaration */
#if defined(DISPLAY_DEV_KIT)
Arduino_GFX *gfx = create_default_Arduino_GFX();
#else /* !defined(DISPLAY_DEV_KIT) */
/* More data bus class: https://github.com/moononournation/Arduino_GFX/wiki/Data-Bus-Class */
Arduino_DataBus *bus = create_default_Arduino_DataBus();
/* More display class: https://github.com/moononournation/Arduino_GFX/wiki/Display-Class */
//Arduino_GFX *gfx = new Arduino_ILI9341(bus, TFT_RST, 0 /* rotation */);
Arduino_GFX *gfx = new Arduino_GC9A01(bus, 15 /* RST */, 0 /* rotation */, true /* IPS */);
#endif /* !defined(DISPLAY_DEV_KIT) */
 * End of Arduino_GFX setting
#define BACKGROUND BLACK
#define MARK_COLOR WHITE
#define SUBMARK_COLOR DARKGREY // LIGHTGREY
#define HOUR_COLOR WHITE
#define MINUTE_COLOR BLUE // LIGHTGREY
#define SECOND_COLOR RED
#define SIXTIETH 0.016666667
#define TWELFTH 0.08333333
#define SIXTIETH_RADIAN 0.10471976
#define TWELFTH_RADIAN 0.52359878
#define RIGHT_ANGLE_RADIAN 1.5707963
/////////////////// Audio Setting ////////////////////////
#include "FatFs_SD.h"
#include "PlaybackWav.h"
#include "AudioCodec.h"
char filename[] = "Time_Audio_16khz_16bit_Mono.wav";
#define BUFFERSIZE 512
int16_t buffer[BUFFERSIZE] = {0};
FatFsSD fs;
PlaybackWav playWav;
// Callback function to feed audio codec with additional data
void writeCBFunc() {
    if(Codec.writeAvaliable()) {
        playWav.readAudioData(buffer, BUFFERSIZE);
        Codec.writeDataPage(buffer, BUFFERSIZE);
int playWavTime;
static uint8_t conv2d(const char *p)
    uint8_t v = 0;
    return (10 * (*p - '0')) + (*++p - '0');
static int16_t w, h, center;
static int16_t hHandLen, mHandLen, sHandLen, markLen;
static float sdeg, mdeg, hdeg;
static int16_t osx = 0, osy = 0, omx = 0, omy = 0, ohx = 0, ohy = 0; // Saved H, M, S x & y coords
static int16_t nsx, nsy, nmx, nmy, nhx, nhy;                         // H, M, S x & y coords
static int16_t xMin, yMin, xMax, yMax;                               // redraw range
static int16_t hh, mm, ss;
static unsigned long targetTime; // next action time
static int16_t *cached_points;
static uint16_t cached_points_idx...
